Schumacher Corner
SILLY QUESTION
With the alloy hinge pin blocks in is marked L and the other R. What is it calling left or right? Is it while looking the car from the rear or the front? Are the letters marked on each supposed to be facing up or down onto the chasis?
I've obviously mispladec the instructions and cant remember if i ever had them on correct.
R.
R.
Yea the R and L is meant for Right and Left . The letters will be facing down and you look at the car from the rear.
mi2
Originally Posted by Jon Kerr
Rubber or foam?
Facing down. Thanks.
snap- foam tires I'd run the solid deck.
mi2
jon thanks for that
hi john kerr, i bought a whole heaps of Mi2 stuff and in that pile came some shumacher R12 alloy front hubs, i was wondering will they fit on the Mi2.
I'm not sure. I never ran the R12 (I'm not a Gas Hole ) Anyone else know?
Kid, the R12 is based off of parts from the original mission, so no the hubs will not work.
Hey Jon what are some good foam tires to use for this car?..Maybe some Parma cyan and magenta 57's ?
That one I can't fully answer. I know PW and most everyone else was using Jaco tires in Vegas but I have no idea the compounds. I would see what the preferred tire is at your track.
Roberto,
Start with the purple , plaid combo, and go from there.
The double pink, Double pink Orange combo is good too..
Double pink/orange and double pink is almost always better with high bite. My car wouldnt even work last year on plaids and purples when it was high bite. When its low traction the plaids and purples work good and dont wear as fast.
If you think he's bad try pitting next to weylin. It's like self induced torture to pit within 30 feet of him.
