Schumacher Corner
#9886
hey just curious what are the numbers mean (6-6.5 or 8) I still new. Just curious you meant tight carpet and opean ashpalt. what about tight ashpalt. I used to run a hight gear on my tc3 never had a problem with over heating. One guy had a bump from c to b mains. ran a high gear on his tc3 with a monster. the monster couldn't handle two heats in a row. ( nice smoke show though) I think I might try my orion core for a bit and see what she has. I'm running 767 brushes. Just had the com cut and new brushes. Just curious about the different spring that are avail.
Man I hope you guy are getting sick of all my question. I just want to show those x-ray, that the mi2 is going ot give them a run for there money.
#9887
The numbers they're posting are the final gear ratios. It's actually 6:1 ratio or 6.5:1 ratio. One thing to remember with gearing, the terminology can be a little confusing. A 6.0 gear is actually higher than a 7.0 ratio. The lower the number, the higher the actual ratio is. A good way to think of it is look at a full size cars transmission. 1st gear or low gear would be, lets say 10.0. (I don't know the exact gear ratios you'd find in a full size tranny) Go to 2nd gear and be maybe 8.0:1. and so on. High gear would be the closest to 1:1. You'll get people argue about this all the time but this is how it actually is.
#9892
Originally Posted by tony rivas
hey guys
I just broke down and got tamiya shocks! What color are the pistons? white What holes to used #2? Thanks guys
#9894
Hello,
GREAT TIP FOR SCHUMI DRIVERS:
I looked on PW's setup of Reedy Race 2005 and he was driving with 2mm higher than standardhole (inner camber link on shock tower)i tryed and it feel GREAT.My car was more stabil when turning into a corner. THX to Jon Kerr beceause he said it was better!!
Greetz from a guy that cant whait untill MI3.
#9897
#9898
end this year i think.TO LONG
#9899
There isn't an Mi3 as it stands.
Paul, what's the deal with running a Corally steering rack??
As for running with the inner ball raised, yeah that is actually a fairly good idea. It's something that we've done over here for a while.
#9900
We started running the raised camber link about a year ago with good results...Check out the BMI towers
MattW...The steering rack was orginally put on so I could test different ackermann and to eliminate the stock bulky servo saver system. I've never been a fan of the stock system and this was the cheapest & easiest way to test a different system.
Mi3...I can assure you that there is nothing yet, just a wishlist from the racers
