Schumacher Corner
Originally Posted by STLNLST
and all of them stayed ahead of you I normally let the Xray guys choose which chassis they would like to get beat with....LOL
Originally Posted by HarshGuy
Yea STLNLST has gone from "car of the month" to "motor of the month" to "chassis of the month"
Hey Jon, Do you by chance have any wheels, Rev-Lites that I can use this weekend? I forgot to order some.
Nope. Sorry.
Originally Posted by Jon Kerr
Nope. Sorry.
bmi chassis
thanks 4 that jon,car looks cool,
im having a problem with the rear of my car i cant stop it from overstering,my car at the min is.
front:
spool
2dg camber
-1 toe
blue spring,45 wt oil
5.5mm droop (with shui gadge)
ride hight 5.5mm
shocks on mid hol top and outer on bottom
1mm spacer on front pivot block
rear
roll bar yellow
3dg toe
2dg camber
ride hight 6mm
droop 4
40 wt oil blue spring
shock 2nd hole from botom (top)
shock 2nd hole from outer (botom)
camber link flat (if u no what i mean?)
1mm washer under rear pivot block
runing with cs-22 tyres, std chassis running on tarmac
thanks bob
front:
spool
2dg camber
-1 toe
ride hight 5.5mm
rear
roll bar yellow
3dg toe
2dg camber
ride hight 6mm
droop 4
thanks bob
Fist off, take the yellow bar off the rear and put on a black 1.5mm bar. Also, are those the stock blue springs from the kit? I honestly never ran those and don't know what they're rated at but I'd suggest getting some Associated Blue and silver springs. Also, take out some camber. I pretty much always run only 1 degree of camber all around. Lower the ride height to 5mm all around. Give those adjustments a try and see how it is.
yeah i will then, but will the ae springs fit std shocks??? yeah blue is the stock set thanks for that i will giv it a go. bob
I think you need to use the old preload spacers under the threaded collar to take up the gap since the AE springs aren't long enough. Someone, if I'm wrong on this, correct me.
o and one more thing, i have made my spool with the diff by taking the balls out and glueing a shui header card on the diff rings is this right becaus i get lots and lots of chatter wen i turn with power on is thins normal ?? it works fine i just dnt like the sound it makes lol.
Chatter is something that happens to pretty much all cars running spools. And yes, you built it the right way. Make sure since you're running a spool that you change the front blades often. You'll notice the spool wears them out quickly.
thats good then thanks, racing sunday i will see how the changes go thanks bob
rw spurs
Hi guys, i was reading this forum ,and i have 2 questions:
1) Im going to use rw 64 pitch 128T spur, am i need something to convert it to fit in my mi2? what?? part numbers please.
2) is it normal u have a little play on the 20t pulley?? what i do to dont have anymore?
Thanks a lot.
Marcelo-Brazil
Thanks a lot.
Marcelo-Brazil
Thanks a lot.
Marcelo-Brazil
Thanks a lot.
Marcelo-Brazil
There is some play in the 20t pulley. RW just came out with a new machined 20t pulley, part# RW1000, I believe that will pretty much eliminate that. I'll be getting one on my next order.
