Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 11-22-2004, 10:14 AM
  #8161
Jack Smash's Avatar
Trader Rating: 35 (100%+)
I can confirm what Adrian is saying.
I asked Korgae about running the old plaid & purple combo when the bite comes up. He said that yes the dbl pink stuff is softer, but the way the tire is constructed, it gives you more forward bite but less side bite so it is ideal to use in high bite conditions. Unfortunately i have 3 sets of the old stuff left to run.
Jack Smash is offline
Old 11-22-2004, 10:44 AM
  #8162
IslandBwoy's Avatar
what is the difference btwn flipping the rear block to add or remove toe and using the links to make the adustment???
Sorry for thew newbie question.
IslandBwoy is offline
Old 11-22-2004, 11:45 AM
  #8163
ottoman's Avatar
Originally posted by IslandBwoy
what is the difference btwn flipping the rear block to add or remove toe and using the links to make the adjustment???
I don't quite understand your question.... the rear links adj the rear tire camber... either the top of the tire leans in or leans out, while the rear toe is how much the front of the rear tires points in toward the chassis
ottoman is offline
Old 11-22-2004, 12:00 PM
  #8164
RCGaryK's Avatar
You're talking about 2 different adjustments. Toe talks about having the FRONT of the tire angles inward towards the chassis, Camber is about having the TOP of the tire leaning toward the chassis.
RCGaryK is offline
Old 11-22-2004, 01:36 PM
  #8165
seaball's Avatar
Arrow *i am looking for a mission two*
hey guys,
yeah, this is kind of an interruption of sorts, but i am selfish and i thought that i would ask.
does anyone here want to unload an mi2? preferably with some sort of heavy lower chassis and a front diff? i would love to run this car, after the cleveland, here at the gate. i have been told it won't work, and now i am hoping to prove that it will. i have not seen many of these in the f/s thread and i am growing impatient.
carry on fellas.
>>> [email protected]
seaball is offline
Old 11-22-2004, 01:38 PM
  #8166
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
haha, I just ordered new rims, tires, suspension, and intake/intercooler goodies for my new car, so a lot of my stuff might be goin up for sale before long
Randy Caster is offline
Old 11-22-2004, 01:43 PM
  #8167
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Dude, you have to atleast drive it once before you sell it.
Jon Kerr is offline
Old 11-22-2004, 02:15 PM
  #8168
Default Re: *i am looking for a mission two*
Originally posted by seaball
hey guys,
>>> [email protected]
Who said this car won't work.
Don't listen to track dummies.
Any car will work with proper setup.
dasupacat is offline
Old 11-22-2004, 03:44 PM
  #8169
Speedie's Avatar
So does anyone know what the belt pitch is on the Mi2 belts?
Speedie is offline
Old 11-22-2004, 05:47 PM
  #8170
PW
PW's Avatar
The info you need should be printed on the stock belts.
PW is offline
Old 11-24-2004, 11:09 AM
  #8171
I wanted to know if any of you Schumacher guys trim the rear belt (narrow it) or clip off teeth to free up the drivetrain. Does that help at all? My rear belt feels real stiff
DOTMAN is offline
Old 11-24-2004, 01:10 PM
  #8172
Jon Kerr's Avatar
I wouldn't suggest it. We used to trim teath on the Losi car but this drive train is free enough there's really no need to do that.
Jon Kerr is offline
Old 11-24-2004, 01:19 PM
  #8173
RCGaryK's Avatar
Yeah, at most pick up the low friction pulley set and you'll be ready to rock
RCGaryK is offline
Old 11-24-2004, 01:29 PM
  #8174
Aren't the pulleys on the Mi2 the low friction pulleys?
DOTMAN is offline
Old 11-24-2004, 01:31 PM
  #8175
Speedie's Avatar
Schumacher sells a narrowed rear belt that helps pn. u2721. The machined diff pulleys make a big difference as well. Ft pulley u2746, rear u2745. My front belt came with every other tooth cut off and holds up well the narrowed rear belt did not last with them cut off tho. The belt will soften up more still if you soak it in WD40 for a week or 2. The machined ones are made of delrin or delrin like material and are slicker than stock ones are.
Speedie is offline
