Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-16-2007, 11:19 AM
  #20836
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by POUNDITRACING
GOOD JOB RANDY. All the guys from the real socal say hi and good job. Do you have any lpans to go to the shoot out?
Thanks Ray, it's cool to make my first ROAR Nats main, and end up on the podium after starting in 7th.. Luck was on my side in A3.
Randy Caster is offline
Old 07-16-2007, 01:14 PM
  #20837
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Great run Randy.
wyd is offline
Old 07-17-2007, 08:22 AM
  #20838
I've had it with trying to get the spool to work (plus its hard on front end parts). In general, what setup changes would one make when changing from a spool to a one-way in a MI3?
qwkpony is offline
Old 07-17-2007, 08:35 AM
  #20839
Trader Rating: 19 (100%+)
GENERALLY MORE REAR TOE AND 6* CASTER BLOCKS
teammidget lilB is offline
Old 07-17-2007, 08:37 AM
  #20840
are turnbuckles m3 or m4
Old 07-17-2007, 09:04 AM
  #20841
M3.
Jan Larsen is offline
Old 07-17-2007, 01:21 PM
  #20842
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
what surface/tires are you running on?
andrewdoherty is offline
Old 07-17-2007, 03:43 PM
  #20843
What is wrong with the spool? What do you need it to do that it isn't doing. I think the Nats track is as tight as it gets and very few people were even trying 1-ways.
Old 07-17-2007, 04:51 PM
  #20844
Trader Rating: 32 (100%+)
hey, would anybody have a manual for a axis 2 that they could scan or xerox ? i know it's a longshot but i figured i'd ask
thefnshow is offline
Old 07-17-2007, 06:02 PM
  #20845
Looking to give the MI3 another shot since I cannot get parts for some other cars out there. Does anyone have a decent carpet setup and are parts available? I kinda wish I would have given the MI3 more of a chance the first time. Please help!
jstikes is offline
Old 07-17-2007, 06:06 PM
  #20846
There is a thicker chassis available for racing foams on carpet, just get that and some XRay 25 and 30lb springs, 6 deg caster blocks, lower the arms all the way and it will most likely be a good base setup to start with. Rubber tire setups, you could always start with most of the asphalt setups already posted on the website.
Old 07-17-2007, 07:16 PM
  #20847
PW
PW's Avatar
Foam or rubber? There are a few guys running foams already and the car has been dialed. I'm sure either Favan or Orlando can give you a good setup for foam.
If your running rubber tire than start with the kit setup in the manual (chris asthon).
PW is offline
Old 07-17-2007, 07:22 PM
  #20848
Sigearhead's Avatar
Trader Rating: 74 (100%+)
No doubt. If you're looking to run carpet on foams. Shoot me a PM and I can hook you up with a setup.
-Favian-
Sigearhead is offline
Old 07-17-2007, 09:19 PM
  #20849
whats the biggest spur you can put on a mi3
Old 07-17-2007, 09:26 PM
  #20850
STLNLST's Avatar
Good job Randy. You are my hero
STLNLST is offline
