Xray T1
#8326
Motor heatsink
Any good ones to be recommened? I only have ones for motors which are mounted in line with the chassis and not across the chassis.
Cheers, Mark.
Cheers, Mark.
#8327
I couldn't find a heatsink that would properly fit in the Xray car without it hitting something. If you know of one, please inform.
#8328
Re: Re: Re: another fk question
Originally posted by markp27
With my luck and incompetence, the springs fly all over the room before I have compressed one of them
#8329
Re: Re: Re: Re: another fk question
Originally posted by Neil Rabara
Do it in a plastic bag.
#8330
Re: Re: Re: Re: Re: another fk question
My incompetence prevented me of thinking about such a good solution
#8331
Re: Re: Re: Re: Re: Re: another fk question
Originally posted by Tom G
Don't feel bad, I would have pondered the same problem and taken 5 years to come up with only half as good of a solution as the palstic bag!
#8332
Markp27,
What time is it over there?
#8333
Originally posted by JohnMatrix
Markp27,
Markp27,
#8334
Rookie XRay question
Do need a belt tensioner with the low ratio pulley set? I put a front one-way in my FOC with a low ratio gear on just it and the belt was really loose. Do I need a tensioner or will it tighten up when I put the rest of the gear set on?
Thanks for the help guys.
#8335
if it is too loose, just rotate the bearing cup in the bulkhead toward the rear of the car. that will tighten the hole belt up.
you only need a belt tensioner if you are too lazy to take the car apart.
#8337
the answer you will here on this forum is "DON'T!!!!!!!"
the car is nto setup for all the bats on one side. Remeber the cars like the tc3 also use the motor to counter balance the battery weight. with the xray, all you have is electronics. and most of us us the small stuff. So not much weight.
#8339
ahhh, that makes sense. I don't believe that you can get 6 cells on one side with the short arm config of the FK. Due to the moutns being on the outside of the bulkheads. I think the 6 cell holder was there for the t1 and evo2
