Old 08-06-2004, 12:15 AM   #8326
markp27's Avatar
Send a message via ICQ to markp27
Default Motor heatsink
Any good ones to be recommened? I only have ones for motors which are mounted in line with the chassis and not across the chassis.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 08-06-2004, 01:33 AM   #8327
Neil Rabara's Avatar
I couldn't find a heatsink that would properly fit in the Xray car without it hitting something. If you know of one, please inform.
Neil Rabara is offline   Reply With Quote
Old 08-06-2004, 01:34 AM   #8328
Default Re: Re: Re: another fk question
Originally posted by markp27
With my luck and incompetence, the springs fly all over the room before I have compressed one of them
Do it in a plastic bag.
Old 08-06-2004, 01:36 AM   #8329
markp27's Avatar
Default Re: Re: Re: Re: another fk question
My incompetence prevented me of thinking about such a good solution
Old 08-06-2004, 02:21 AM   #8330
Tom G's Avatar
Default Re: Re: Re: Re: Re: another fk question
Don't feel bad, I would have pondered the same problem and taken 5 years to come up with only half as good of a solution as the palstic bag!
Tom G is offline   Reply With Quote
Old 08-06-2004, 02:27 AM   #8331
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: another fk question
Then my 10 years don't look too shabby
Old 08-06-2004, 02:31 AM   #8332
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Markp27,
What time is it over there?
JohnMatrix is offline   Reply With Quote
Old 08-06-2004, 02:34 AM   #8333
markp27's Avatar
Originally posted by JohnMatrix
Markp27,
Just a moment, got to stick my sundial out of the window 10:33am - pretty good sundial I have
Old 08-06-2004, 07:16 AM   #8334
JHardy's Avatar
Default Rookie XRay question
Do need a belt tensioner with the low ratio pulley set? I put a front one-way in my FOC with a low ratio gear on just it and the belt was really loose. Do I need a tensioner or will it tighten up when I put the rest of the gear set on?
Thanks for the help guys.
JHardy is offline   Reply With Quote
Old 08-06-2004, 07:22 AM   #8335
theisgroup's Avatar
if it is too loose, just rotate the bearing cup in the bulkhead toward the rear of the car. that will tighten the hole belt up.
you only need a belt tensioner if you are too lazy to take the car apart.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-06-2004, 07:26 AM   #8336
JHardy's Avatar
Oh thats what those are for..... Thanks.
One more thing ... I am going to run 6 cells on one side but they dont fit between the bulkheads .... is there anything I can do?
Old 08-06-2004, 08:09 AM   #8337
theisgroup's Avatar
the answer you will here on this forum is "DON'T!!!!!!!"
the car is nto setup for all the bats on one side. Remeber the cars like the tc3 also use the motor to counter balance the battery weight. with the xray, all you have is electronics. and most of us us the small stuff. So not much weight.
yang lai
Old 08-06-2004, 08:20 AM   #8338
JHardy's Avatar
Guess I should have added that Im running it on a flat carpet oval track with very tight turns.
Old 08-06-2004, 08:24 AM   #8339
theisgroup's Avatar
ahhh, that makes sense. I don't believe that you can get 6 cells on one side with the short arm config of the FK. Due to the moutns being on the outside of the bulkheads. I think the 6 cell holder was there for the t1 and evo2
yang lai
Old 08-06-2004, 08:29 AM   #8340
JHardy's Avatar
Oh yeah...I have an EVO 2... right now its setup with C-Hubs on the front and pivotball on the rear. I dont think its the short arms. Could be wrong though.
There is so many things about this XRay I am not use to yet.
