Xray T1
#2536
X-Ray Setups Needed
If you have a good X-Ray T1 setup, please fill out this form, and I will add them to my website.
http://www.balakracing.com/setupform.htm
Thanks in advance
Bryan Balak
Balak Racing Webmaster
Thanks in advance
Bryan Balak
#2537
Re: X-Ray Setups Needed
Thanks in advance
Bryan Balak
Thanks in advance
Bryan Balak
Log into myTSN.com, there you will find numerous Xray setups for different tracks and conditions.
#2538
Originally posted by RCCadet
Lets see....tell him.....the guy that manages a track with Mike in Texas says Hi. I asked Mike about Tony this past weekend.
#2539
I have a question about my xray: Why is it so slow?
Oh I gotta take it out of the pit bag and run it sometime
Neil, since I know you comb this thread more than say the "Tevo3" thread, here's a reminder to bring your transponder this Saturday. Also, don't forget to bring some packs and a charger and most importantly, your "A-Game."
If the weather's poo poo and the track is flooded, I'll call you.
Cheers
Cheers
#2540
I have a stick pack ready to go, the only thing is it is set up to be hard wired. No connectors on it.
#2541
Thanks in advance
Bryan Balak
Thanks in advance
Bryan Balak
C'MON!!!guys.I know yall! got a good set up to share.Ware are the Texas GUYS AT THAT DYNOMAN allways tells me about?You guys ain't greedy are you?Or are you guys as fast as Dynoman says you are?
#2542
Here's the magic set where we run:
Follow the setup guide included with your Xray and use the pro front one ways.
Easy enough
Easy enough
#2543
whats the best top deck for evo 2 on carpet
#2546
The best neutral setup is the recommended setup in the book. The one-way is nice if you want to corner a little bit faster.
#2547
Ok!so you guys are telling me that you are still running the stock set up out of box?or are you guys telling me to look in a book and let it explain to me about set up?Because I have tried a set up that is sugested out of the set up book but it was a little too loose fo me.I was just wondering if everone in this thead who owns a x-ray is running carpet.Most who I talk to and chat with is running carpet.
I was just wondering bout a good set up (other than stock set up)that someone has good luck with on asphalt.
#2548
Littledog :: I race on asphalt and concrete for which the stock setup is not a good starting point. My setup sheets are dated and our track surfaces will vary to some degree, but have a go with my setting found on HTRLrc. Click the link below.
I use c-hubs now but I will post a new setup sheet soon.
#2549
