Xray T1
#2386
Afternoon All,
Does the EVO 2 come with (305215) (305315) Spring Steel Front & Rear wheel Axle with Hex Hub??
Thanks Guys!
Thanks Guys!
#2387
RC _Zombies
I am impressed you think the car i sold you was only ran twice. Actually I ran brushless mod foam and stock rubber with the car you purchased for at least half the season. I guess that gives a testiment to how durable and long lasting the xray with c-hub really is. Not a part on that car has ever need to be replaced other then diff rebuilds, and cvd blades. Pretty cool eah?
SWG
SWG
#2388
Originally posted by HPI666
Afternoon All,
Thanks Guys!
Afternoon All,
Thanks Guys!
#2389
i broke the flexible upper deck on my x-ray so i have to get a new one. Question is should i get a stiff upper deck or the stock flexible one. I plann on doing carpet racing so would it also be a good idea to get anti-roll bars front and rear as well as stiffer springs (which ones?)
#2390
warlord385
I used to race an evo on carpet m8 so i might be able to help....need a few answers first though !
what sort of carpet ?
what tyres did you have in mind ?
are you using the c-hub ?
mod or std motor ?
as for the top deck solid one less flex is better on high grip surface
mod or std motor ?
#2391
Uhh not sure on the carpet
foams
no c-hub
stock and modified motor
foams
no c-hub
#2392
too many vairations m8
my mod set-up was much more forgiving than the stock 1
anyway for a starting point
violet springs alround 1 hole in from outside
50w oil 2 holes open front 3 rear
anti rollbars front and rear 75deg front 1mm rear(smallest anyway)
proline double purples front
proline purples rear
4.5 < 5mm ground clearence alround
steering arms outer mountings inside and at hubs
2 deg negative camber alround
2 deg tow in rear
0 deg at front
2 deg tow in rear
0 deg at front
#2393
warlord385
also try the my-tsn vip room set-up pages
#2394
Anybody converted to C-hubs and want to sell there pillow ball arms and hardware? lmk email me at [email protected]
thanks.
thanks.
#2395
Looks like the New X-Ray
C Hubs all around.... Looks like this will be a great car even though it is a sport car. Looks like you get some of the good stuff from the EVO2 without the $500 pricetag for EVO2 + all the C Hub Stuff.
IF THE PICTURE DOES NOT SHOW UP RIGHT CLICK ON THE X AND CHOOSE sHOW PICTURE... FOR SOME REASON MINE DOES NOT SHOW UP ALL THE TIME.
#2396
The picture isn't coming up.
#2397
#2398
Whoa, that looks nice!
#2400
Originally posted by rc-zombies
Now we have the option to buy 2 versions of the EVO2. Pillow suspension or C-hubs!
