Xray T1
#1637
I have not benefited from a one-way on a medium to small track that is technical and/or tight. I don't recommend it.
I would recommend a one-way to try it, but I prefer a locked diff on tight technical tracks.
#1640
Well, I seriously considered the EVO 2 as my next purchase but the wheels have fallen off that wagon.
Personally, I hate pivot ball suspension designs and because of that, I was keen to get a C hub conversion when buying the kit. After reading about the dubious front arms, I was a little discouraged but the shocker really came when I found out the price.
X Ray EVO2 kit NZ$ 730
C hub conversion NZ$ 305
Sorry, I'm can't pay almost half the kits value for some suspension parts alone. Alloy suspension components just don't do it for me so it's "bye bye" potential X ray.
Now, I don't know anything about producing a kit but....
Would it be prohibitively costly to make the pricey alloy parts from Composite? Does the cost of creating the Composite plastic mould(vs Machining alloy blocks)make it a "too expensive" alternative?.
Is it possible to market two kits, one with Pivot ball suspension and another with Composite plastic C hubs as standard?
I'm not suggesting a simplified "RTR" kit, but it gives potential purchasers a choice of car that would suit their needs(Especially if the C hubs do change the handling characteristics of the car)
#1641
Originally posted by STLNLST
Corse R- Is that yok insert that you want to test with is the new thin one......save your money. It's too thin (IMO) and allows the tire to squirm in the corners. The 32's (IMO) are a waste of a tire. They only work when the sun and the planets are all in line...LOL
For not being completely off-topic. I'm having problems with the front belt skipping on my new Evo2 - up to the point sometimes the belt escapes from the pulley. Is that normal? on what position you people put the front eccentric? - Mine was at stock position (I think so....).
#1642
Why is quite pricey? Because from the pivot ball suspension, the unique piece you use on the new suspension is the connection between the universal and the front hub. All the rest is brand new (the same goes to the rear suspension). That's which is so high priced.
But if you want, you can get the front and rear suspension separately and then isn't so scorcher the price but... the best you can do is ask for a local to test their pillow ball car and test it (this is what I did and convinced me instantly) I was a 3 years old TC3 driver and fell captured by this car.
#1644
Originally posted by Corse-R
[B]
But if you want, you can get the front and rear suspension separately and then isn't so scorcher the price but... the best you can do is ask for a local to test their pillow ball car and test it (this is what I did and convinced me instantly) I was a 3 years old TC3 driver and fell captured by this car. B]
[B]
not to be a pain, but these prices are unthinkable...........
#1645
I am happy with mine. I have a T1 and the C-Hub conversion. C-Hub adds a ton of steering. I installed the rear 2 weeks ago. Adds additional steering and I had to dial this out. I am going back to pillow ball in the rear. I actually prefer pillow ball.
#1646
after losing the A main in stock carpet by around a second yesteday (and i had closed up the gap only in the last minute), i am looking for any tips or anything for carpet. i am running hte c hub front, and the car handles great, but i need an extra .1 or a second here and there if possible. so i was thinking, is there a "not aviable to the public" top deck for carpet racing? since i have the flexi one (which was included in the evo 2 that i bought), but the chassis flexes so much i find it hard to believe that the regular strenth one will do the trick.
also i have been running a tc3 for a few years, i know how to free up that drive train, but what do i do for an xray ray? i normally take off the inside shield of the beairngs, spray it out, and put a very lightly beairng on it. but what do i do for the belt? i have heard some people soak it in wd-40?
i am looking for anything here! lol
#1647
DTM- What inserts are you using in the 33r's and what track temp do are they best used in?
#1648
#1649
STNLST: I've noticed that the 32's arent as good as 28's, but I figured that is a personal fixation and 36's ............
#1650
Originally posted by stormperson
........... is there a "not aviable to the public" top deck for carpet racing? since i have the flexi one (which was included in the evo 2 that i bought), but the chassis flexes so much i find it hard to believe that the regular strenth one will do the trick.
You have the "thinner" Racing belts with the Evo 2.....not a good idea to use WD40...will leave you with a belt which is smoother...but will stretch very quickly.....those racing belts don't come cheap!!
