Xray T1
#1682
Originally posted by jesse370
Ok i finished building it and put the electrics in the car. I was really really impressed with the acceleration of the kit. I don't think I'll be missing my tc3 one bit. But I have a question the front belt is real loose. I have the front eccentric hubs on the notch that would be at 9 oclock. And by the instructions that is as tight as it goes. And I didn't notice a bit of difference at all in the tension of the belt. Its so bad I can roll the front belt off the diff pulley if you coax it a little. Is this something I should worry about? My last belt touring car was a hpi mini that had a belt tensioner. And input would help, the belt does seem to tighten some on power so I guess I'll see what happens at the track?? But so far I think this kit is really free, and is more free than my associated that is being replaced by this kit.
i think you may have put the eccentric hubs in the wrong locations. i've had to put mine in the 4 oclock position(initial instructed setting was to put in 6 oclock). give it a try, it should be ok.
#1683
Jesse, there correct. I spent over 2hrs. assm. and dis-assm. the frontend until I found out the instructions were backwards. I've since made a tensioner out of a servo horn with a couple of bearings. Now I don't have to rip the front apart again just to change the tension. I run it loose in stock and semi-tight in mod. I ran my EVO2 outside with rubber tires had an 8x1 in it and I walked every nitro car at the track on the straightaway!!! I love the car.
#1685
Has anyone tried to convert the old Serpent shocks to the new Evo 2 shocks with the alloy shock bodies??
I tried tonite and found the plastic cap holding the O-ring in place does not fit the new Evo 2 shock bodies!!! There is a very slight difference.........
#1686
Originally posted by Trinityracinnut
I agree i ordered the belt tensisoner. so now i can assemble it the way they say and not have to do ne thing.
#1688
Ah well....at least I'm not alone!!!!
#1689
well i got my evo2 and just finished building it last night. excellent quality! except for a couple parts, the rear bulkhead brace was not tapped at one end so i emailed xray, and the wheelbase clips. but i love all the features of the car and cant wait to try it out next week.
#1690
#1691
I agree with dtm on the clips. Worth the effort. I have done this twice as I have c-hub also.
#1693
I am having to order a new top deck, there was a section of the track that had changed from others hitting the turn......and I let off the throttle to adjust and the guy behind me pushed me into the turn. I snapped only one side of the top deck at the base of where it splits so I was able to use a home remedy and glue to continue with my last qual and main.
That added flex seemed to agree with the car, so I will try the original flexible top deck this weekend and see how it runs.
#1694
Originally posted by RCCadet
Someone on another discussion board found out the same thing you did about the shock bodies.
#1695
ya i spent what seemed like forever getting the thickness just right on wheelbase clips with the dremel but now i have near no play with bind free suspension.
rc cadet what surface are you running on, ashpalt?
