Xray T1
#1831
Floaty rear end
Right at racing today i ran the C hub front suspension and the ball rear suspension and the back would just not grip, it just seemed to skim over the track no matter what i did. I race indoor on carpet. I had yellow springs all round and 30 wt oil in the shocks can anyone throw any ideas my way as to what to change? Thanks Rick
#1832
What else have you done?? Currently I'm running 50wt 2 holes open front and back with red spring ft. and violets in the rear. without swaybars. I also tried the front oneway. Played with the camber links and ani-dive in the rear. I've been fighting to get more steering and all along the rear has been tight. (as in mega bite) I started to get the rear loose and finally got steering. Now all the rear bearings are bad (blue shields) so I'll be replacing them this week.
#1833
i have had alot of problems with the handling of my xray.
one of the main culprits seems to be the shocks. they leak out the top. i have tried filling them up mulitple times and even changing the bladder, nothing seems to work. i have the alum shock bodies btw.
also the car flexes, really badly. i tried installing the original upper deck (from the first xray) over the evo 2 flexable deck, since i could not just use the stiff upper deck (due to the lack of a notch for the steering bellcrank). however, as a result the belt rubs along the upperdeck.
has anyone else had these problems?
#1834
Has anyone had trouble with the blue seal bearings?? I've had my car for less then 2 months and had to replace all the bearings. There so gritty that they won't clean up. Should a person have to tear apart the whole car and clean the bearings every week to keep them in good shape?? I had to replace the front axle bearings (green seals) in my T1 shortly after I got it as well. After that I never had problems with over a year on the front bearings and they were still smooth.
#1835
I race on a track that is not blown off and one that is. I do clean my bearings after each race day to prepare for the next. The blue 'shields' are great but do let tiny bits of debris past them. Heck..... I had a shield spin off the bearing so it was resting on the outdrive.
#1836
i race on carpet, and i have actually had the sheilds come off the blue bearings. i have never had bearings that do this, it is the oddest hing...
#1837
Regarding the flex on your car is natural and is developed with some flex in mind. If you want a car who don't flex I suggest another car with a monolitic chassis like a TC3, XXX-S or a MR-TC. Mine (Evo2) worked flawlessy with some chassis flex. Makes the car more docile and predictable.
Have you tried to file a little those notch rather than putting a second upper deck?
#1838
the reason i actually got the alumuinm bodies is because the plastic ones tended to strip out. is there any sealant or anything i could put on them possibly?
and yes i realize that the car is going ot have some flex, although i dont see why they designed it in there. wouldnt you prefer to tune your car with your shocks and suspenion, instead of having to tune the chassis? i just dont get the point of having a flexing chassis, with all of the suspenion changes you can make...
#1839
stormperson, I'd have to agree... I'd rather have the chassis stiff and work on the suspension. My original T1 was very stiff all stock. I may get the T1 chassis and upper deck since I run saddle packs anyway. Plus the car is light enough to not worry about the difference in weight.
#1840
A FLEXABLE CHASSIS IS JUST ANOTHER TUNING OPTION AS THE OTHER GUY SAID JUST FILE OUT A NOTCH ON THE SOLID TOP PLATE AND INSTALL THIER WONT BE ANY FLEX AT ALL. BUT FOR CARPET RACING YOU WANT A LIITLE GIVE IN THE CHASSIS CAUSE IT MAKES THE CAR A LITTLE MORE PREDICTABLE WHILE CORNERING MAINLY FROM THE CENTER OUT
#1841
#1842
thats why they list the stiff upper deck for the evo2
#1843
HobbytownRacer: Thanks for the info on the shocks you gave me. Got some longer 3mm screws and 3mm nuts so I can use the ultra tune rear with my pillow ball setup.
#1844
Mike does the upper deck you have for me have the plastic piece
#1845
nitro, did you get them to work?
