Old 10-06-2002, 07:56 AM   #1831
Default Floaty rear end
Right at racing today i ran the C hub front suspension and the ball rear suspension and the back would just not grip, it just seemed to skim over the track no matter what i did. I race indoor on carpet. I had yellow springs all round and 30 wt oil in the shocks can anyone throw any ideas my way as to what to change? Thanks Rick
Rick Draper is offline   Reply With Quote
Old 10-06-2002, 01:14 PM   #1832
GregH's Avatar
Send a message via AIM to GregH
What else have you done?? Currently I'm running 50wt 2 holes open front and back with red spring ft. and violets in the rear. without swaybars. I also tried the front oneway. Played with the camber links and ani-dive in the rear. I've been fighting to get more steering and all along the rear has been tight. (as in mega bite) I started to get the rear loose and finally got steering. Now all the rear bearings are bad (blue shields) so I'll be replacing them this week.
GregH is offline   Reply With Quote
Old 10-06-2002, 08:01 PM   #1833
stormperson's Avatar
Send a message via AIM to stormperson
i have had alot of problems with the handling of my xray.
one of the main culprits seems to be the shocks. they leak out the top. i have tried filling them up mulitple times and even changing the bladder, nothing seems to work. i have the alum shock bodies btw.
also the car flexes, really badly. i tried installing the original upper deck (from the first xray) over the evo 2 flexable deck, since i could not just use the stiff upper deck (due to the lack of a notch for the steering bellcrank). however, as a result the belt rubs along the upperdeck.
has anyone else had these problems?
stormperson is offline   Reply With Quote
Old 10-07-2002, 05:16 PM   #1834
GregH's Avatar
Has anyone had trouble with the blue seal bearings?? I've had my car for less then 2 months and had to replace all the bearings. There so gritty that they won't clean up. Should a person have to tear apart the whole car and clean the bearings every week to keep them in good shape?? I had to replace the front axle bearings (green seals) in my T1 shortly after I got it as well. After that I never had problems with over a year on the front bearings and they were still smooth.
Old 10-07-2002, 05:29 PM   #1835
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I race on a track that is not blown off and one that is. I do clean my bearings after each race day to prepare for the next. The blue 'shields' are great but do let tiny bits of debris past them. Heck..... I had a shield spin off the bearing so it was resting on the outdrive.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-07-2002, 06:22 PM   #1836
i race on carpet, and i have actually had the sheilds come off the blue bearings. i have never had bearings that do this, it is the oddest hing...
Old 10-07-2002, 11:52 PM   #1837
Corse-R's Avatar
The leaking on your shocks can be culprit for the aluminium bodies, return to the plastic and see if continues to leak.
Regarding the flex on your car is natural and is developed with some flex in mind. If you want a car who don't flex I suggest another car with a monolitic chassis like a TC3, XXX-S or a MR-TC. Mine (Evo2) worked flawlessy with some chassis flex. Makes the car more docile and predictable.
Have you tried to file a little those notch rather than putting a second upper deck?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-08-2002, 05:04 AM   #1838
the reason i actually got the alumuinm bodies is because the plastic ones tended to strip out. is there any sealant or anything i could put on them possibly?
and yes i realize that the car is going ot have some flex, although i dont see why they designed it in there. wouldnt you prefer to tune your car with your shocks and suspenion, instead of having to tune the chassis? i just dont get the point of having a flexing chassis, with all of the suspenion changes you can make...
Old 10-08-2002, 06:23 AM   #1839
GregH's Avatar
stormperson, I'd have to agree... I'd rather have the chassis stiff and work on the suspension. My original T1 was very stiff all stock. I may get the T1 chassis and upper deck since I run saddle packs anyway. Plus the car is light enough to not worry about the difference in weight.
Old 10-08-2002, 06:28 AM   #1840
mike5009's Avatar
Send a message via AIM to mike5009
A FLEXABLE CHASSIS IS JUST ANOTHER TUNING OPTION AS THE OTHER GUY SAID JUST FILE OUT A NOTCH ON THE SOLID TOP PLATE AND INSTALL THIER WONT BE ANY FLEX AT ALL. BUT FOR CARPET RACING YOU WANT A LIITLE GIVE IN THE CHASSIS CAUSE IT MAKES THE CAR A LITTLE MORE PREDICTABLE WHILE CORNERING MAINLY FROM THE CENTER OUT
mike5009 is offline   Reply With Quote
Old 10-08-2002, 06:50 AM   #1841
dtm
dtm's Avatar
Send a message via ICQ to dtm
On the old upper deck, the hole is offset and the plastic insert is concentric. On the Evo 2 upper deck the slotted hole is central and the plastic insert is offset. To run the old upper deck on the Evo 2 you need the old concentric plastic insert, otherwise the steering post will be bent.
dtm is offline   Reply With Quote
Old 10-08-2002, 07:05 AM   #1842
GregH's Avatar
thats why they list the stiff upper deck for the evo2
Old 10-08-2002, 07:06 AM   #1843
RC Nitro's Avatar
HobbytownRacer: Thanks for the info on the shocks you gave me. Got some longer 3mm screws and 3mm nuts so I can use the ultra tune rear with my pillow ball setup.
RC Nitro is offline   Reply With Quote
Old 10-08-2002, 07:06 AM   #1844
GregH's Avatar
Mike does the upper deck you have for me have the plastic piece
Old 10-08-2002, 07:08 AM   #1845
GregH's Avatar
nitro, did you get them to work?
