TA-05 ver.2
#1051
Super Moderator
Watched a brand new one run 17.5 at are big race 2 weeks ago and it worked great. My guess and 99% of the time it is not put together right.
Simply try putting it together again. More than likely you simply overlooked something and then to compound the problem the more you look at the more your probably not seeing it.
#1052
Guys please help
The problem is vibration and noise as if the dog bones had come out when turning to the right or left. It's OK if there is just a little turn or when dead center.
It was suggested to get a Spoll and a 46mm universal. I did, it's installed and the problem persist.
Look at the videos. The big riddle is when I take of the tiers the vibration stops, there is nothing toching or obstructing the wheell as it turns, I also tried difrent wheels/tiers, same thing.
With tiers on:
No tiers on, semms fine!
If you have Skype my handle is yogi.marcos I apreciate your help.
Marcos
With tiers on:
+ YouTube Video | |
+ YouTube Video | |
Marcos
#1053
Tech Legend
Trader Rating: 51 (100%+)
That is a common problem that almost every car that uses a spool has. Speedtech RC has some drive shaft setups from Spec R for the Tamiya 416 that stops that problem but they are 40 bucks and out of stock. It has nothing to do with the TA05 being a bad car. Its almost every high end car you can think of. Here is the link to them. http://www.speedtechrc.com/store/ebp...id=619&id=9042
Every high end car that does not have a lvd dual type driveshaft has this problem. My TC5R has it, the 416, 415, TAO4, TAO5, Cyclone, Sukura Zero, MI3, E4 all have this problem. Xray does as well unless it has the special driveshafts and they are only make for a few cars. The only car that never has this problem is the Losi JRXS and JRXS Type R since Losi developed the special two piece swing shafts needed to fix the problem and had a patent on it.
Spec R has them that fit the Schumacher MI4, Xray, 416 and the ones for the 416 should fit the TA05 IFS V2 and TB03 since they have the same short a arm setup and hubs.
#1054
That is a common problem that almost every car that uses a spool has. Speedtech RC has some drive shaft setups from Spec R for the Tamiya 416 that stops that problem but they are 40 bucks and out of stock... catmainid=619&id=9042[/url]
Every high end car that does not have a lvd dual type driveshaft has this problem....
I don't understand how can the car be run as is, let alone race? you can't take a tight turn without it braking and going out of control.
Anyway thanks, Wyd.
Any other suggestion?
Marcos
#1055
I just bought the 46mm swing shafts (steel front aluminum rear) to get rid of that problem. The same thing happened with me when I was using the dog bones. If I made a left or right turn around a 180 turn, my dogbone would pop out and my car is stalled.
Ever since going with the swing shafts, that is a problem of the past. You can get the Tamiya EVO IV swing shafts since they are 46mm as well. Worth every penny.
#1056
the problem is offically called drive line chatter. EVERY car you can buy will do it. My tb03 does it, just way less because of the cvd,s. you have to turn down your steering throw until chatter is about 20%. you built the car fine. THE only way to fix this is buy getting the speedtech part mentioned above.
As soon as they are in stock i will get a set. Notice they make those drive shafts for ALL the high end 500.00++ kits.
It is a normal part of the design for rc cars until they all switch to a spec R type setup.
I run my steering throw(the amount the wheels turn) at 85%
so I took away 15 % of my steering on my tb03 to get rid of the chatter. good luck and you are not crazy
now...your car seems to have a problem with the inside of your rim hitting the very ends of your suspension arms at full steering throw.
this happens when you run a 26mm rim on a car designed around a 24mm wheel. I had the Same exact problem as soon I put on the 26mm rim. You have to put a 1mm thick shim on the axel to fix this problem. see the pics below.
the shim is the small round black circle. Hpi rims come with a 1.5 mm hex shaped spacer with the wheels to fix this problem. Notice the wheels that came with your kit have ( + 2mm) stamped in little letters on the outer edge of the rim. They are 24mm with a 2mm offset so they do not rub. Put in a spacer...get some cvd,s and you will be happy like us all Your video did the trick too
tired of typing bdhbdpv..mndv now
#1061
Thank you!
The good news is that there is a solution! The bad news is that is makes my wallet an extra $40.00 lighter. Actually it will be $40 plus $24 for the spoll and $20 for the 46mm universal. $84.00 more just to get it to do what it's spoused to do after building it.
So allow me a small steam release gesture (hope you guys don't mind too much) I will re-state my previous remarks (but now with concrete evidence). The Tamiya TA05 V2 kit stock quality is CRAP
I guess I can use the 46mm universal that I have now in the front for the back?
Fat500 I will follow all your suggestions and keep you in the loop.
Cheers,
Marcos
#1062
Tech Legend
#1063
Tech Legend
Fat 500 & HarryN, I am grateful for your help. It's so cool to be able to have this forum for advice and specially problem solving. This RC idiot really appreciate's it.
Cheers,
Marcos
Cheers,
Marcos
#1065
Want to run fast? This is what the best toll look like:$
I only have Tamiya cars, and two have been problem-less out of the box: the F103R and the old Grop "C" chassis/C11 (the older of the lot and the most easy, fast and stable). This sedan (my first) and another direct drive kit the F103RM needed at least 50% extra investment on top of the kits purchase price just to get them running correctly
I gess this RC thing causes addiction
Cheers!
Marcos
