TA-05 ver.2
#2551
Trader Rating: 38 (100%+)
#2553
I had a ta05 a long time ago, before I made the switch to lipos. I wanted to get another TCS car and saw the gold edition and thought it would be good...I'm not a fan of the TA06 and the gearbox/belt, as I see as an inefficient ripoff of the HPI RS4 from looooong ago.
So the TA05 with milling of the chassis' insides...would this be allowed in a TCS race? In hindsight I Kinda wished I kept my TA04.
#2555
Thanks....anybody used shorty packs with success?
#2556
#2561
When I am setting up a chassis I will go through the following steps:
-Final weight and L/R balance (I added 34+ grams to the battery side, to get my L/R even)
-Ride Height (5mm F--5 1/2mm R)
-Droop or up travel (2 to 3mm over ride height)
-Camber (2* all around)
-Front Toe (1* out)
#2562
TAMIYA TA05 ver2.
Hi all..
I new this hobby RC 1/10..
I just brought TAMIYA TA05 ver2 just done building...
hope any best recommended setup on road high speed..
1.chassis setup
2.ESC,Motor,Heat sink,
3.Damper
4.Servo
5.Battery and Charger
6.Pinion,Spur,Moter Gear
7.Tire and Wheel
8.Radios and Receiver
1.chassis setup
3.Damper
4.Servo
7.Tire and Wheel
#2563
I run the M-Four and you'll probably want to get the Kyosho o-rings for your oil diffs as they will begin to leak at the outdrives.
Kyosho PN: ORG05
Also recommend Associated GreenSlime on the diff gaskets to prevent oil from leaking out the belt side.
Kyosho PN: ORG05
#2564
Here is a good place for info to get started:
http://www.petitrc.com/reglages/tami...TamiyaTA05.htm
And finally, there's already a TA05 thread to answer all your questions:
http://www.rctech.net/forum/electric...ing-sedan.html
#2565
I'm sure Sagadsetup, aka Mr. TA05 will confirm but the stock v2 came with ball diffs I believe.
So much for my 15yr haitus, littleZEN!
