TA-05 ver.2
#1036
can the aramid belt be used on th version 2?
#1038
Tech Legend
Trader Rating: 51 (100%+)
Going to put spool in my new IFS v2 and looking to put these in so I don't get any chatter at full steering throw. Anyone try these out as they are setup to fit the 416, IFS v2 and TB03 or at least that is what is said in the description.
I know a buddy uses the same brand in his MI4 and it works perfectly and no wheel chatter from the spool.
http://www.speedtechrc.com/store/ebp...id=460&id=9042
#1039
man, reigle running a plastic tub car? say it aint so!!!
R
R
#1040
Plastic bathtubs
-Andy
#1041
Tech Legend
WHere did you order your swaybars from? I found most of the stuff I want at Speedtech or Tower from one part Speedtech didn't have. Looking to order that stuff very soon.
#1042
Tech Legend
No worries about scratching it up and way more forgiving than my other cars. Since I don't run much I need a more forgiving car that its easier to drive most of the time and the Tamiya 05's do this well. Another cool thing is the car is very unique with the laydown suspension and it don't hurt that it actually works well to.
Got a good deal on the car and I watched Andys with his first time at Frederick and it was smooth and easier to drive than most.
#1043
pully play
hay guys i`m new to t05 v.2 ifs and my f&r pullys have some play side to side and the kit didn`t come with shims ... i just finished puting it togeather lastnight and painting starts tomarow.i`m looking to start raceing on a carpet track and a paved out door track.... thanks for any help...
#1044
Spoll and 46mm universal = No fix
Same thing happens to me, I put more sponge to try hold the right dog bone, no good. Also the diff becomes lose easily after a soft or medium bump and it losses all front pull. When it starts tail out spinning in the turns, or turning hard right as I brake, it's a sing that front the diff went louse.
I was not gladly surprise to see how cheap the stock diff/drive train is for the TA05 V2.
So I spent another $40 for a direct spoll and a 46mm universal set.
Marcos
Marcos
Will try and make a video.
Help
Marcos
#1045
It's all in the droop settings! Every other setting is stock from the manual, minus the springs and sways.
#1046
Tech Legend
Yeah, that is one thing I love about the TA-05 v2. I am not a good driver, but man is that car so forgiving. Very easy to set up as well since it has such a huge sweet spot, even with using sway bars!
#1047
Lot's of problems in the TA05 V2
The TA05 v2 is cheap and the front drive train apperas to be a major design flop for Tamiya. Just read the previous pages.
Is there anyone that can help us with the front train set-up please?
Thanks, Marcos
#1049
Tech Legend
O well I guess my post and some others that are having problems with the front diff set-up (stock and spoll) did not happened, maybe is just our imagination
Thanks, Marcos
Thanks, Marcos
Simply try putting it together again. More than likely you simply overlooked something and then to compound the problem the more you look at the more your probably not seeing it.
#1050
try rebuilding the front diff. I have built mine and the diffs are the same as my tb03. super quality. heck just rebuild the whole car.
I can tell you for sure you will have wwaaayyy more trouble with the tb03 if you can not get this one going. the 05 has a way more simple drivetrain and way easier to adjust. I have both cars and got the ta05 because it is easier to work on the driveline on the ta05
be patient and ask a fellow racer for help at your local track if all else fails.
