T.O.P. Racing "Photon" 1/10 EP Touring Car
#4516
Trader Rating: 20 (100%+)
Another GREAT weekend for TOP! Race was held at NC.
Majority of the A-mains were Top cars in 13.5 class and 17.5 class!!
Great job for Timmie and crew!!
Another sweep for TOP!
Tony ... See you soon!!!
Arv.
Arv.
#4517
Loosening up the ball cups
I just went through all my ball cups to loosen them up. I was able to get just about every ball cup nice and loose with just once spin of the body reamer from smaller hole of the ball cups except for the lower shock ball cups. I went as far as 3 turns on the lower shock ball cups and they don't seem to loosen up.
Has anyone else done this? I'm kinda worried about reaming them anymore. Anyone else experience this?
#4519
#4520
I got just about as much threads showing. It does not look like they are bulging through.
I put some 18.5mm ball cups on there(only because those are the only spare ball cups that I have), and I was able to get those to be as free as the rest of the ball cups on the car. These might have been damaged at some point. I'll pick up some new lower ball cups and that will hopefully do it.
#4521
Ballcups
I had the same problem due to winding them in to far and cousing a bump on the inside of the cup. I just used the ingraving tip off my Dremmil and moved it in circles inside the cup till it freed up. Now I leave 1.5 mm thread showing of the shaft as advised by one of my clubs photon drivers. End of problems
#4522
#4523
TOP
Solid Axle set
Solid Axle set
#4525
This is my friend made to me !
so we don't want release !
but TOP was making ,
so please wait moment !
#4526
I've been looking at several of the Photon setups on Tchub and many like to sweep the front arms back by placing a larger washer behind the front front hinge pin holder versus the front back. In affect adding toe out.
What does this do versus just dialing in toe via the steering turnbuckles?
#4528
so what's the advantage to a gear diff?
#4529
#4530
