T.O.P. Racing "Photon" 1/10 EP Touring Car
#4367
Spool issues
Hi Chaps
Just wondering if I am the only one still having spool problems. I have just noticed that my 6th spool in 5 months is gone . When I say gone I mean the steel out drive is just turning in the now round hole (started out square). I am not over or under tightening it and it always happens on the motor electrics side. After the 3rd one went on me I have been very careful when building them and maintain my car to a high standard so cant understand what it is. Any help or opinions I would be great full.
Apart from my problems with spool I love this thing.
#4368
I have been running the same spool in my primary car for about 9 months now. Its the very first one that EJ sent me when they went to the harder V3 spool I think it is.
I haven't seen anyone around here having rounding out problems since the spool was updated sometime around Sept 09. What class are you running?
#4369
#4370
Hi Chaps
When you tap or hit the pipes ,were you on throttle?
#4371
Hi Chaps
#4374
Spool issues
Wow fast responses
I am only running 17.5 also the drive spins fine without the motor in place or pinion removed. If and when I crash I try to drop the throttle as soon as possible. I have spoken to all the local photon drivers and I seem to be the only one with this problem so it has to be something to do with the set up or driving style. Oh also the countersunk screws are the ones that come with the top racing steel spool outdrives.
Switching back to the Roche spool for a bit until I can figure it out. Would prefer to use stock parts though really.
Many thanks for all the input so far though guys
#4375
Does it only happen after a crash? Something weird is going on because it shouldnt be happening with a 17.5 motor. I thought maybe you were running mod on a track with boards and trying to bounce off of them?
Check to make sure the screws arent too long. Its possible you have too long of screws in there and you put the side that isnt having a problem first and its in all the way and then when you put in the side that is having a problem its not getting fully tight? Check that out and let me know.
#4376
Spool issues
No that was also what I thought could have been happening but I measured the screws on the last 2 spools to make sure.It also happens if I use the plastic ones. Always on the motor side as well never happen on the battery side. Bearings have been replaced all round so it shouldn't be one of them sticking. and new dogbones on the front too.
#4378
Spool issue
Thanks for ides though mate.
