LRP Vector x12 Brushless Motors
#273
Hi.
I'm new here, and noticed this thread. I've got a LRP Vector X-12 5.5 on my Team Associated B44 –*do you guys have any recommended gear setup for this car?
Cheers.
Cheers.
#275
Allright, thanks.
I'll try an 18 or 17T pinion then. I've got the stock 84T spur.
#276
Has anyone tried a 10.5 in 1/12 as i have one and its not performing blac diamind esc latest version motor ok for 6 mins then slows tried everthing even got new armature for 1cell 3.7 lipo but no good
thanks
thanks
#279
Hi, i just got a 13.5 x-12 and for the timing inserts, i recieved two of the 3-dot inserts in the small zip lock bag, plus the 0degree already in the motor. i was just wondering if this is correct or should i have gotten the full range of them.
#280
I seen a couple of guys running low turn motor using the Turbo function of Hobbywing's esc without any problem on 3.5t, 4t and 5.5t. They are not using the X12 tho but i do own one 4.5T Octawind which is just lying about and wondering if i'd be able to get some kicks out of it via my Tekin Rs Pro.. Any advise before i blow up something???
#281
Installed the 4.5T octawind on my tekin rs pro. Wires was all good, A-A, B-B ,C-C. Switch it on, throttle it a lil, the motor spun a bit then POP! The motor is brand new and i rechecked all the wiring and nothing was done wrong. How could this happen????
#283
I haven't heard a solid report from anyone that has run both motors back to back to tell what they feel is different.
#284
You more than likely broke the rotor. As Red Bull said it's not wise to free rev the motors especially with the timing boost turned on.
#285
rito: sxx tc spec v2 with x12 4.5t octawind, settings/fdr for Speedworld rubber touring, please?
thanks
thanks
