XRAY T2’009
Old 01-09-2009, 09:51 PM
  #346
Suspended
Can you use the tape for the battery with the specialize plate?
kyosho player is offline
Old 01-09-2009, 10:41 PM
  #347
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
i like the atomic batteery strap so you can use the battery as ballist instead of having to add weight ,it is worth it, i drilled 2 extra holes to do 2 more mounting points on each side also it gives you a place to add weight if you dont want to move the pack out as i did
my balances out @ 1433g with 0 weight and i only moved it out about 3/8"
adding weight under the pack makes you have to add even more weigth to balance because the weigth near the center dosnt do mutch good to balance the car ,it just makes it heavier
jlfx car audio is offline
Old 01-10-2009, 02:19 PM
  #348
Damon's Avatar
Originally Posted by kyosho player
Hey DAMON,
Where did you get that lipo plate from? Also,when using the lipo plate,can you use the tape for the battery?
thank you
it's home-made by an Italian boy
yes, I can use the tape, but it's also arranged for the original battery strap
Damon is offline
Old 01-10-2009, 02:50 PM
  #349
Gettin' a T2 '09 soon..
Recommendation of option/spare parts needed for competative racing..
such as... antiroll bar... springs....
Are they any other colour coming out soon?
Sleepstream is offline
Old 01-10-2009, 03:41 PM
  #350
maby springs but that is it
Old 01-10-2009, 10:58 PM
  #351
Ran the car for the first time tonight. It was more stable than the 007. So far I really like it. I'd rather run a oneway though. The 008 multi diff will fit this car right?
M3dreamin2008 is offline
Old 01-10-2009, 11:07 PM
  #352
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
yup, there weren't many changes from 008 to 009. its more like an evolution car. unlike 007-008.
rx7ttlm is offline
Old 01-10-2009, 11:09 PM
  #353
rx7ttlm's Avatar
so I will post pictures later. but I am running Lipo with the PPB machined weight and 3mm of roll center spacers to get the strap to work with the xray lipo topdeck update. looks sexy and i Shoe goo'd the battery to the plate so I don't have to worry about it getting into the spur/ pinion
rx7ttlm is offline
Old 01-11-2009, 12:13 AM
  #354
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Originally Posted by ChristopherKee
Hey Karl, just use the Specialized RC one for the T2 008/009. www.corallyusa.com
Have used this as well with the PPD. It works well and with SMC lipos the car needs about 40grms to get it to race spec. No need to tape batt's in etc.
Regards
Kyle
Kyle Hazell is offline
Old 01-11-2009, 12:20 AM
  #355
lookinco's Avatar
Hey guys, I will be running the T2 009 indoor on a carpet track. How do I tell between a low traction and a high traction carpet?
I have a bunch of Sorex 28R tires and some Sorex Type A and Type B insert, what tires combo should i go with?
Thanks!!!
lookinco is offline
Old 01-11-2009, 02:39 AM
  #356
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hey i was wondering does the 009EU Kit come with the graphite lipo pads, or are they an option part?
Yokomo_Ant3 is offline
Old 01-11-2009, 03:19 AM
  #357
Yes, the come with the kit as std.
Regards
Kyle
Old 01-11-2009, 03:25 AM
  #358
Regards
Kyle
Cool Thanks Kyle.
Old 01-11-2009, 05:50 AM
  #359
Trader Rating: 14 (100%+)
I like the looks of this plate. THe price seems a little high. Anybody tried it.
https://www.ssl-stormerhobbies.com/c...s&pn=MAN134101
rushrush1 is offline
Old 01-11-2009, 09:50 AM
  #360
Hey does anyone know where I could get a 008 multi diff for the 009? Nexus and Stromer are on back order.
