TAMIYA F103 RM
#587
take a look at them, its the TRG body.
he says both are different models but if you look they are both the same just with different paint jobs.
to be fair to him his paint skills are really good, he says he has used ltd or never released tamiya decals, im betting he's got a vinyl cutter!
#590
Thanks for all your inputs. I'm really new to electric stuffs. So does that mean I can use a GTB with fan(because then I won't need to buy another ESC) in the F103, with a brushed motor? And also I cannot use a lipo with brushed motor here? Somehow I see that the GTB with fan seems rather tall to fit in the F103.
Cheers.
#591
Hi All,
Cheers.
Cheers.
The GTB, if I'm not mistaken, is just slightly bigger compared to the LRP TC spec. I have attached 2 pictures for you to see how i mounted my TC spec on the F103 and there is still room to spare. Do take note that i mounted my receiver vertically.
In the Philippines, when we run our F1 club races, most of us use the orion 3600 and 3800 lipo packs.
hope this helps
#592
#593
Hi TitaniumR
hope this helps
hope this helps
#596
#597
Anyone see this? "RC HP Racing F103RM (w/Body) - F103"
http://www.tamiyausa.com/product/ite...oduct-id=84032
#598
Just wanted to point out Vyger's new F1 thread. He detailed some body painting and decaling tip which I thought were helpful: http://www.rctech.net/forum/electric...-whatever.html
#599
mark
#600
Both the ball & o-ring suspension battery holders have a negative impact on handling. For best results I would suggest using the o-ring suspension set and tape the battery in instead of using the holders. If you look at the pics of the soon to be released hop-up chassis you will see that the battery must be taped in as suggested.
mark
mark
Is there instructions on how to build it with the o-ring suspension rather than the ball? The RM manual only shows how to build the ball suspension.
James
