Tekin RS ESC sensored
#8011
#8012
I tried to find the post, but I don't have time right now. I could have sworn the RX8 is an RS in a bigger case with better cooling. That means it will do everything the RS will, just with better cooling and more weight.
I also recall people going to the RX8 in mod class because it was better at cooling.
#8013
Yes, i need RS PRO. I live in Russia, and i cant buy it your local shop
#8014
The RX8 was tested in extreme mod TC using Lipos, 5 cell with motors down to a 2.5t.
It doesn't have the ability to go into sensored only mode which is fine since in MOD you're not going to want that. It works just fine as it shares programming with the RS line.
#8016
Turbo affects top speed...it does not provide extra acceleration to obtain your top speed quicker. The maximum on the Turbo slider is 20 degrees of timing.
The 30 degrees reference is a suggested maximum between motor timing and boost timing. Turbo is an addition of timing and is capped at 20 degrees maximum you can add.
#8017
#8021
Yup try a new sensor wire...if that doesn't work then clean out the motor really good with motor spray. Sometimes dirt can get on the sensors and cause the same problem.
#8023
#8024
Krio, if motor spray is isopropylic alcohol is it OK then to use it on the sensors? Isopropylic alcohol is sold as "electronics cleaner" under a lot of brands and it is especially for cleaning electronics (I have been using it for a long time with all my other speedies and all sorts of other electornics as well, without any problem) as it does not attack plastics and evaporates without residue.
#8025
Hexane, Propane, Isopropanol, n-butane, and Isobutane. While plastic friendly for the most part, they are not ideal for electronics.
