Old 06-18-2010, 02:20 PM   #3316
YoDog's Avatar
Trader Rating: 26 (100%+)
Here are some pics of the battery tray installed.
Team Magic E4 Thread-img_0421comp.jpg   Team Magic E4 Thread-img_0422comp.jpg   Team Magic E4 Thread-img_0420comp.jpg   Team Magic E4 Thread-img_0423comp.jpg   Team Magic E4 Thread-img_0424comp.jpg
YoDog is offline   Reply With Quote
Old 06-18-2010, 02:27 PM   #3317
YoDog's Avatar
A few more...
Note that the battery pack is a Fantom 5200mah/50C.
as long as you have a standard ROAR legal hardcase pack, it should fit quite nicely.
Some of the older SMC packs are not likely to fit due to the very sharp corners and extended length. (139mm ROAR max.)
The tray at this time has a 138mm X 47mm cavity.
Old 06-19-2010, 01:54 AM   #3318
Mitch-e4fs's Avatar
Default Ride height problem
Hi all
I recently bought an e4fs and have been having some problems getting the ride height down to a reasonable level, I've found some setup sheets for carpet racing and they all want a 4-5mm ride height with team magic pink and purple springs. But those springs are much longer than stock and particularly in the rear I need 6mm or more droop to get the car to sit right. Is this right or am I missing something with my setup?
The car is used for 540 racing with a 4000mah lipo and a min weight of 1.425 kg
Mitch
Mitch-e4fs is offline   Reply With Quote
Old 06-19-2010, 09:16 AM   #3319
hacker's Avatar
Trader Rating: 141 (100%+)
so I'm on the look out for either this or the losi. The losi seems to have quite a bit of success, whereas this car I have not heard of doing much. Or please correct me if I'm wrong.
Does this car get it done in the big events?
losi pretty much dropped all their drivers, but still do ok in the hands of privateers.
hacker is offline   Reply With Quote
Old 06-19-2010, 05:31 PM   #3320
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
How old of a version is the E4RS that has dual steering bell cranks? Is this the 09 version or an older car than the 09 E4RS?
ST Racing Concepts (STRC)
Old 06-19-2010, 05:54 PM   #3321
hacker's Avatar
correct me if im wrong, but I thought the e4rs was introduced in 2009, so all the e4rs are 2009
Old 06-19-2010, 06:08 PM   #3322
blis's Avatar
The rack steering is on the Orginal E4 and I think latter JS.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 06-19-2010, 06:29 PM   #3323
Mitch-e4fs's Avatar
Any help with my earlier post?
Old 06-19-2010, 06:41 PM   #3324
blis's Avatar
Default Tyre diam?
I was going to mention tyres.. running foams? at what diam? My rubbers are at 62mm and IC foams start at > 64mm.
I dont think there's downstops on an E4 and the only time Ive had prolems like that the CV's or the Sways were locking up and thats mainly on a G4
Oh and one other, no spacers under a ball end cap and it bound on Losi car.
So remove your shocks, ensure everything is free and happy.
Old 06-19-2010, 06:50 PM   #3325
blis's Avatar
Default Mitch...
Notice you in ACT, here in Brissy.. If you need I can slap some full foams on my son's and get the geometry for you. With shocks off, enusre they are working well and are you using correct shock ball caps and can check the length.
Old 06-20-2010, 02:05 AM   #3326
Mitch-e4fs's Avatar
Thanks for the offer, Im using foams at 63 ish mm, no sways on the rear (where the problem is) Nothing is locking up or binding.
Its just that i have to use more droop to get the ride height, , which is also putting some pretension on the springs. Without this droop im at about 9mm high in the rear. The fronts need no extra droop with the shock collars wound all the way up to.
Ill try to get some pics up and the setup im trying to use is the Olivier gremillet Trets-ligue setup from the Petitrc website
Old 06-20-2010, 02:06 AM   #3327
Mitch-e4fs's Avatar
Its just that i have to use more droop to get the ride height, which is also putting some pretension on the springs. Without this droop im at about 9mm high in the rear. The fronts need no extra droop with the shock collars wound all the way up to.
Old 06-20-2010, 03:15 AM   #3328
Mitch-e4fs's Avatar
These are some pics from my car,
The second is the droop with shocks on,
The third is the droop with the shocks off, is this ammount of flex usual?
The fourth is the stock springs and the Team Magic springs for the E4
Team Magic E4 Thread-imgp0001.jpg   Team Magic E4 Thread-imgp0005.jpg   Team Magic E4 Thread-imgp0006.jpg   Team Magic E4 Thread-imgp0007.jpg
Old 06-20-2010, 12:30 PM   #3329
Jochim_18's Avatar
If you are going to use springs other than Team Magic springs you have to use a short springs like tamiya short spring or K-factory. Other manufacturer have a longer springs thats why you are not getting the proper ride hide. You can make it work but you have to replace the shock retaining cups with associated ones I believe.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-20-2010, 12:31 PM   #3330
Jochim_18's Avatar
Don't use droop to adjust your ride you are going to have handling issues.
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
