Team Magic E4 Thread
#3166
Team Magic E4 did really well today on MOD class... It's just really easy to drive I don't have to fight with the setup, The car transition really smooth in transfering weight left to right, Easy to drive on high speed corners.
Weak part of the car is the dogbone and front belt.
#3168
#3169
Thanks I just purchase a new TM E4 09' Rubber Spec last night. Do I need the Lipo kit on this car or it will fit bigger packs no problem?
#3170
You need to space your top plate 2 mm to accept the 5000MAH lipo's and dremel some of the front middle axle holder and a small bit at the front of your side tensioner bracket that's it
regards Roy
regards Roy
#3172
Not a e4 owner guys....but I might be in the future. I thought the 09 RS has a different mount setup made for larger motors and allowing for more battery space? I believe it's the only version with such changes. At least thats what the website leads one to believe.
#3173
#3175
Which spring you guys are using I know it needs a shorter spring to get a proper ride height...
Tamiya make a short Spring Kit anyone you guys tried one?
How about the K-factory spring kit it's on the expensive side but if it will work on the E4 I wil get one...
Thanks guys I'm looking forward on running the E4 at the REEDY Race this year in open MOD.
#3179
yes they are a direct fit. when i bought the car (its an older e4 ive had for a few years and still love it) it had the tc5 retainers and the shock ball ends were trimmed down i think. i bought all new ends and retainers and the springs and can get the ride height i need. hope it helps
