Tamiya mini cooper
#8341
servo
Speed - 0.12sec/60degrees
Torque - 7.4kg-cm
$39.99 only
http://www.speedtechrc.com/store/ebp...nid=62&id=8079
#8342
What's this?
There's only one way to find out.
Visit rc-mini to find out the scoop on the coolest M03 chassis ever...
#8344
hi
which dumper do you recommend??
i would drive onroad
http://www.rcmart.com/catalog/rc-dam...?cPath=389_390
or
or the original tamiya???
trf..? too expensive for me
thanks
Moole
or
thanks
Moole
#8345
hi
or
thanks
Moole
or
thanks
Moole
#8346
My opinion would be to stay away from the Yeah racing damper. I recently bought a few sets and was disappointed. One large problem I have found is that when you pull the piston out to insert spacers inside, the orings inside the shock tear apart and the travel becomes stiff. The orings can be removed by taking out a retaining ring but I wouldn't waste your money. I've heard the mini cva dampers are good enough. The other issue with the Yeah racing shocks are that the springs are too long and you will need to buy a short set of springs. Also the shock end connection is too long and needs to be ground down with a file or dremel. I think I'm going to pitch mine in the garbage.
this
Tamiya Super mini shock 50746
and
Tamiya Springs 53333
do yeah racing and 3racing work toghether?
#8347
R/C Tech Elite Member
The 3Racing dampers are pretty good. Fairly well constructed, and the right length for a mini. The bonus is that they're a hell of a lot less expensive than the Tamiya units.
If you do choose to go with Tamiya, get the plastic Super Mini CVA set. They are all you'll ever need.
Jim
Jim
#8348
I have a lot of on power push. My car handles awesome, I just dont want to slow down as much when I go into the corners. Whats a good way to get a little less on power push?
Shocks have white rear and red front springs. I thought of giving myself a little toe out, that should help, right?
#8349
Regional Moderator
Any of you guys have any experience running the M03 with the long wheel base. I've been running my M03M for as long as I've run mini. But I was interested in extending the wheel base and trying it out to see how I like it.
I run both carpet and asphalt, so any thoughts on how it works on either or both would be nice.
#8350
#8351
However this is a quote from the RC-Mini.net:
It does NOT matter which wheelbase you run. Any one of them is fine. I repeat again - It does NOT matter which wheelbase you run
At our biggest meeting of '07, the top 3 cars were all different wheelbases. If that's not proof enough, we don't know what is. Go to the 'events' section for a full run down on that. Just pick whatever bodystyle you like, and the appropriate wheelbase.
Some people will try and tell you that there's an appreciable difference between the wheelbases, we've yet to see proof of it.
#8352
Darkseid There's not much difference between the various wheelbases. I've found the short might be a little twitchier on turn in than the longer wheelbase, but the setups are pretty much the same.
Portyansky As suggested, shorten those shocks. I was running mine fairly tight as it was and the car handled well. I've got them to the point now where there's almost no droop and the car is slammed, and it handles like it's on rails.
Jim
Jim
#8353
I've got the Mini CVAs with blue spring, with the adjuster turned in all the way, with a medium and thin spacer on the springs, and still have what seems to me, quite a lot of droop. What is your ride height measuring under the front bumper? I don't mind a little less push either.
#8355
Oh, so apart form the 5mm spacer inside, I have to put more spacers? I see on the mini CVA V parts tree, there seems to be another spacer inside of Part V7, it looks like about 3mm, this is the one?
