Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-11-2009, 07:47 AM
  #8311
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
Hey guys.
I just got my parts from dinball.
I ordered the 3Racing graphite front and rear stiffener. I am confused how they mount though. Do they go against the shock tower or in front of the shocks?
Anyone with a picture would be great.
Thanks!
SerpentCT4S is offline
Old 02-11-2009, 09:11 AM
  #8312
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Whats the hot ticket in lipo's for mini's?
mrrcguy is offline
Old 02-11-2009, 11:07 AM
  #8313
tony gray's Avatar
They mount directly onto the front of the front tower, and to the rear of the rear tower.
So on the front the order is shock - stiffener - tower
And...they look cool but don't actually do anything...
Whatever fits. There are only a limited number that will fit. Core 3200, Orion 3200, Yeah 3200, Harris 3200, Harris 3700, Intellect 4000 etc...
tony gray is offline
Old 02-11-2009, 11:22 AM
  #8314
cely's Avatar
Wink diff
hello
whitch ball diff do you recomend me:
Tamiya 53070
http://www.rcmart.com/catalog/rc-oth...th=595_744_972
3racing alum ball diff
http://www.rcmart.com/catalog/rc-tl0...th=595_744_707
i would buy this but its sold out (is the 53070 similar?):
Tamiya 53267
thx
cely
cely is offline
Old 02-11-2009, 11:27 AM
  #8315
tony gray....thanks for the help.
i thought they wouldnt do much but carbon fiber always looks good sp i bought them.
Old 02-11-2009, 02:09 PM
  #8316
Originally Posted by cely
hello
Tamiya 53070
Tamiya 53267
thx
cely
The Tamiya Manta Ray ball diff is similar to the TA03 one. Both will work fine. Ihaven't used the 3Racing so I can't comment on it.
Sydewynder is offline
Old 02-11-2009, 02:47 PM
  #8317
hairy's Avatar
jolley should know.
hairy is offline
Old 02-11-2009, 04:55 PM
  #8318
Kevin CBR's Avatar
Originally Posted by Sydewynder
You need to remove the F3 and F4 extension pieces in between the motor mount and the main chassis to go from M04L to M04M
Thank you !
This is the body I will be building the chassis for.
Kevin CBR is offline
Old 02-12-2009, 01:12 PM
  #8319
portyansky's Avatar
Trader Rating: 54 (100%+)
Can anyone settle a little debate. I just wanted to know, if the radials that come with the m03r, are infact the s-grips. The numbers are the same on the sidewall as the the s-grips, but it doesnt say s-grips.
Porty
portyansky is offline
Old 02-12-2009, 02:38 PM
  #8320
I'll go for the TA03 diff if you're going for tamiya. Heard that the Mannta Ray's diff is a little more heavier than the Ta03's..
Ben.C is offline
Old 02-12-2009, 03:09 PM
  #8321
Porty
My "R" came with the #50683, standard kit tires, which do look like S grips but are nowhere near as grippy.
mariob62 is offline
Old 02-12-2009, 03:11 PM
  #8322
Core Creations's Avatar
Trader Rating: 110 (100%+)
No, they are the kit style hard compound radials. Not S Grips.
Porty
Core Creations is offline
Old 02-12-2009, 03:41 PM
  #8323
portyansky's Avatar
thanks guys.
Old 02-13-2009, 03:48 AM
  #8324
Starteur's Avatar
How much AW grease should we put in a gear diff ?
We are in test mode now and would have liked to try to lock our gear diff partially before trying a ball diff.
Thanks as always
Starteur
Starteur is offline
Old 02-13-2009, 04:32 AM
  #8325
I know you'll hear otherwise on here...mostly from those that run with more power than a silver can. But I shim mine rather than use the AW grease. The grease, even though thick, it will heat up and sneak out of the gear case and make a mess. I use 2-3 shims per side where they call for 1 on each side in the instructions. It makes a tight diff without completely locking it.
Thanks as always
Starteur
