Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-25-2009, 02:52 AM
  #8191
tony gray's Avatar
Check out this AWESOME TA04 Mini conversion.
On rc-mini.net now.
It's a brilliant piece of work
tony gray is offline
Old 01-25-2009, 03:44 AM
  #8192
On rc-mini.net now.
Looks nice. What was used for the shortened front belt?
Sydewynder is offline
Old 01-25-2009, 07:33 AM
  #8193
DRAG_ON's Avatar
running this will be lots cheaper ......
DRAG_ON is offline
Old 01-25-2009, 08:47 AM
  #8194
R/C Tech Elite Member
monkeyracing's Avatar
Damn! I was doing to build one of those! You beat me to it.
Does it work well?
Jim
monkeyracing is offline
Old 01-25-2009, 09:07 AM
  #8195
DRAG_ON's Avatar
Does it work well?
Jim
have not test it yet,........... look promising all you have to do to strengthen the join plate.........use carbon fiber should do it.............with transmission well if you want to put 20 pinion on the rear you have to do a little drill so the motor pinion can get close enough to internal gear. Maximum size m03m pinion is 20 and m04 is 21 so far i put 20 and 21 just see how it goes.............
DRAG_ON is offline
Old 01-25-2009, 09:14 AM
  #8196
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
A shorter front belt
Dan is offline
Old 01-25-2009, 04:47 PM
  #8197
robus's Avatar
And from remaining parts you have a trailer
robus is offline
Old 01-25-2009, 04:54 PM
  #8198
Turbo Turtle's Avatar
Trader Rating: 21 (100%+)
Who makes that heatsink and where can I get one?
Turbo Turtle is offline
Old 01-25-2009, 06:43 PM
  #8199
Starteur's Avatar
I found on rc-mini and printed that article a few months ago because it was talking about a Muchmore stickpack equaliser or discharger, when I go on their website I can't find that item, has it been discontinued?
Has anyone experimented with that?
Did you have good results?
By the way Calvin I found some fuel line for my shocks so the MINI will have its maiden trip next saturday (I'm getting my new wheels on thursday).
Thanks again for all the help you guys are so nice to newcomers!
Starteur
Starteur is offline
Old 01-26-2009, 12:12 AM
  #8200
Benzaah's Avatar
Trader Rating: 24 (96%+)
Ive used these before when i had stick packs and it was really good. Great punch out of the packs but i found that i could only use them once a day at that level. Having to cut holes in the sides of the packs is a bit of a hazard and Be careful not to short out your packs like i did once. Harris Rc have them listed as in stock but I'd get some lipos though. Much better solution if your series allows it....
Benzaah is offline
Old 01-26-2009, 03:40 AM
  #8201
Starteur:
I've just bought one, and noticed a improvement on my packs especially the cheaper un-branded cell packs! I've got a pack of CHEAP 1500mah cells, and they would only charge to 1100mah bought a Stick pack equaliser and now they take just over 1600mah .
A bit expensive (probably buy a cheapish Li-po for the price!!), but
well worth it!
4_cell_racer is offline
Old 01-26-2009, 03:54 AM
  #8202
Trader Rating: 76 (100%+)
http://www.harrisrc.com/Electronics.htm
2nd item down on page
- Tony
addicted is offline
Old 01-26-2009, 10:56 AM
  #8203
Starteur's Avatar
Anywhere in North America I can buy this?
Starteur
Starteur is offline
Old 01-26-2009, 11:41 AM
  #8204
tony gray's Avatar
See this?..
It's a Mini (Tims Mini actually) going 85km/h, that's why it's a little blurry. And also it's about 10mm OFF the track.
On the r/hand side picture is the very next lap. And it's about 100cm+ off the track now!
Want to see more? Go here to see the pics and video from Velodrome '09 today
Old 01-26-2009, 03:23 PM
  #8205
@Dan Haha you @#$%^&*
@Tony Gray Any ideas on the front belt for the short TA04?
