Tamiya mini cooper
#8221
I want the Abarth Fiat 500 body
#8222
And...Surprise, surprise, surprise... The 'New Release' list for Tamiya at the Nurnberg Hobby Fair in 2 weeks time in Germany contains this little gem.
58427 - Fiat 500 (M03M)
Finally a new shell for the MWB car...
#8223
Springs!
Right I've been searching this thread for the past hour or so read about shocks/springs (guess what I'll be dreaming of tonight!! )
Any way was reading reply 3378 and it was mentioned that 3 set of springs might be needed
So my Q is, would all the springs out of these 2 set be different stiffness's? or I get just 53440 set (seeing as there's a extra spring!)
Thanks in advance guys
Tamiya (#53163) On-Road Tuned Spring Set
Tamiya (#53440) On-Road Turned Hard Spring Set
#8224
It all depens if you are going to run oil shocks 50746 or the friction shocks!
If you run the friction shocks then spring kit 53333 should do the trick if you put a 5mm spacer ( fuel hose) like tony says on rc-mini.net. If you are going to use the super mini oil shocks then get the short spring: 56630-56631-56632.
Please refer to posts #8176-8177-8181 wich aren't that far back.
Hope this will help you, I've been through this step already and this is what the guys sugested.
Don't forget about the ride height it is VERY IMPORTANT!
Have fun
Have fun
#8225
#8226
Those looking for springs for the lowest ride height:
The springs that come as a set of three or four are not the shortest springs you can get. The individual packaged pairs are shorter. Tamiya 53630-53631-53632-53633, Red - Yellow - Blue - White
@Low E
I think he means to get the car as low as you can to prevent traction roll
@Low E
#8227
Quick Question
Hey girls and guys, just a quick question, im buying a Suzucki Swift MO3M, my first mini im so excited, anyway the question is does the stock kit come with an electronic speed control if so can this ESC handle the black can motor.
Cheers George
Cheers George
#8230
#8231
Thankyou
#8233
hey mango dont knock the cheapy esc. Best thing about minis is the cost and that little speedy is perfect for them. These cars cant take much past a black can, and the speedy handles that, and i have minis with the TEU speedy and other with GTX's, i cant notice the difference.
#8234
Have fun
Have fun
I just need to know if all the springs out of them 2 sets above are different in there stiffness (no idea what other word to use there sorry )
If they are the same then there's NO use in me buying the 2 sets, I may as well just buy the 53440 set as that has a extra spring
Cheers
Lee
#8235
People reckon you can run a 27t motor off it, thats probably about it.
But ultimately if you are serious about running a mini you would be better off running a brushless ezrun system (which we run in australia). The black cans will die after about 4-5 meets and at $25? a can you would be better off biting the bullet and putting in the brushless system which will have much more consistent and long lasting performance benefits.
The only exception to that would be if you can somehow get your hands on one of the older black can motors.
