Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-30-2007, 08:03 AM
  #3706
muahdib4's Avatar
Originally Posted by minidriver
They just changed it to Mid April - dang!
Ha, Ha....I'll have mine put together before yours is even available...
muahdib4 is offline
Old 03-30-2007, 09:24 AM
  #3707
Core Creations's Avatar
Trader Rating: 108 (100%+)
Here is my carpet setup:
Front:
2mm ride height
2 deg toe out
Stock bump steer
Thick swaybar
70wt. oil
3 hole piston
6mm internal limiter (allows 1.5mm droop)
Blue short spring
S-Grips with Stock foam inserts with sidewalls CA'd
Rear:
2.5mm ride height
40wt. oil
3hole piston
No swaybar
4mm internal limiter (allows 3.5mm droop)
Red short spring
Type A slicks with stock foam inserts
Gear diff dry and shimmed almost to a spool.
Awesome and pretty easy to drive. It is also not tippy like most of the setups I've seen. You really have to screw a corner up to make it traction roll and most the time if it does start to tip it won't go all the way over, just lift 2 wheels. For whatever reason the tire choice and insert works realy well.
Core Creations is offline
Old 03-30-2007, 09:30 AM
  #3708
...and this is the body I plan on running this summer...it uses the short 208mm wheelbase, but with a Swift body!
http://www.abchobby.com/abcframe/inf...ges/swift.html
Old 03-30-2007, 09:42 AM
  #3709
muahdib4's Avatar
LOL!!! I had thought about the Fit....
http://www.abchobby.com/abcframe/inf...pages/fit.html
But I thought we were going to stick with Tamiya only. Guess I can get even more creative then... Don't make me get a worm...I will and I'll RACE IT.
muahdib4 is offline
Old 03-30-2007, 11:20 AM
  #3710
Yeah, I know...but since it doesn't really enhance the car and it's an alternative to the Cooper... I will for sure be running the SWB from now on though.
Old 03-30-2007, 12:23 PM
  #3711
muahdib4's Avatar
Servo and a few connectors will be here today so I can actually finish my M03M and see how the mid-wheelbase fits me and then I can decide which one will end up being the one loaned out to people wanting to try it...oh and some cheap parking lot cones so my friends who want to race but are to nervous can get a little wheel time before venturing onto the track with all those blasted 2x4s and flappers that like to flip my car over.
muahdib4 is offline
Old 03-31-2007, 06:03 PM
  #3712
Scottrik's Avatar
Trader Rating: 261 (100%+)
Hey...
Anybody who's bought (or might buy) a Tamiya RTR for whatever reason, I'd be interested in buying the radio/receiver/servo that you probably didn't want to use anyway. Might even buy the ESC. Preference to chanels OTHER than 5, but can make that work as well.
Let me know what you've got.
Scottrik
Scottrik is offline
Old 04-01-2007, 05:29 PM
  #3713
RobS's Avatar
Hey guys,
My local track is starting up a Mini class and one of the rules is that you have to run the Tamiya ESC that comes with the kit. The problem I have is that the receiver is is not getting any power and the ESC is making a beeping noise. I've tried everything I can think of but nothing works. I know I'm probably overlooking something but if anybody has any insight into what my problem could be it would be much appreciated!
RobS is offline
Old 04-01-2007, 06:01 PM
  #3714
Scottrik's Avatar
If your esc and receiver are like mine, you have to connect BOTH leads from the esc to the receiver...the three wire lead to the Ch 2 and the two wire lead to the Batt slot. For whatever reason Tamiya couldn't get the power to the receiver via the three-wire lead.
Scottrik
Scottrik is offline
Old 04-01-2007, 06:02 PM
  #3715
I had the same problem. It turned out that my reciever was fried. Did you try plugging the throttle into another slot on your reciever? A friend of mine had to plug the throttle into the steering slot to stop his from beeping.
Hope this helps.
Johnny9s is offline
Old 04-01-2007, 06:32 PM
  #3716
RobS's Avatar
Scottrik
That was the problem, I knew that extra lead had to serve some purpose. Thanks!
RobS is offline
Old 04-01-2007, 06:54 PM
  #3717
Scottrik's Avatar
Yeah, guess who just went through the same ordeal with the "beeps" yesterday. Those darn instructions can come in handy
Scottrik is offline
Old 04-01-2007, 07:44 PM
  #3718
Tim K's Avatar
Yay! my M03R has landed!
Attached Thumbnails Tamiya mini cooper-m03r-1sml.jpg   Tamiya mini cooper-m03r-2sml.jpg   Tamiya mini cooper-m03r-3sml.jpg
Tim K is offline
Old 04-01-2007, 07:50 PM
  #3719
TENCHO's Avatar
hey, thats great! you got your M03R already. we're still waiting for ours.
Does anyone know how to make the tamiya mini wheels fit on a Corrally Mini Assassin?
TENCHO is offline
Old 04-01-2007, 07:56 PM
  #3720
Trader Rating: 24 (96%+)
where did you order from?
nemix is offline
