Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-18-2007, 09:41 AM
  #3856
muahdib4's Avatar
Originally Posted by Three
I have a Futaba 9650 servo mounted in my mini, but have encountered the following problem: The servo mounts keep moving. Have tried just about everything except glueing them but to no avail. New screws, lockwashers, nothing seeems to work. Have verified that there is no contact between the servo saver (Kimbrough mid-size #201) and chassis. Also the end points are such that no contact is made between chassis and front uprights (Tamiya aluminum #53523).
Must be TCS legal.
Mine tended to flex occassionally too. Over the weekend I stole the aluminum servo mounts from the M03R which have 2 screw holes per side and that LOCKED my servo in place. No more flex even if I tried.
muahdib4 is offline
Old 04-18-2007, 09:55 AM
  #3857
Three's Avatar
Would gladly use the aluminum mounts from the M03R but do not believe that they are available without buying the kit.
Do you have a part number? Maybe they are also used in another Tamiya kit.
Three is offline
Old 04-18-2007, 11:13 AM
  #3858
StoneMan's Avatar
I put a small amount of sho-goo at the rear/left corner of the servo. Stops it from flexing.
You can still split the case open to access the gears by removing the right side mounting screw only.
StoneMan is offline
Old 04-18-2007, 11:16 AM
  #3859
Core Creations's Avatar
Trader Rating: 110 (100%+)
Mine hasn't had any problem flexing...I just reduced the endpoints on my Tx until it didn't over throw . If I left my EPA at 100% it had at least 20% too much throw in the servo and would flex the servo up once the cars steering had no more throw.
Core Creations is offline
Old 04-18-2007, 11:17 AM
  #3860
muahdib4...this is what we need next. A full 1/10 size M03 with a hatch. They are re-releasing it in a week! And it runs $48 from Champ!!
Old 04-18-2007, 11:55 AM
  #3861
muahdib4's Avatar
What's the model #? I'm assuming that's an M03L and that's the only difference. I'd run that Peugeot in a heartbeat. I won't be able to get one until the first of the month though.
muahdib4 is offline
Old 04-18-2007, 12:02 PM
  #3862
K_Spec_RC's Avatar
hey cool! TE37's for my mini! it would be ok to run those wheels correct? Assuming the track runs TCS rules of course.
K_Spec_RC is offline
Old 04-18-2007, 12:08 PM
  #3863
No it's a full 10th scale with a slightly shorter wheelbase and a full 190mm width...#58224. It's on Champs site.
Old 04-18-2007, 12:13 PM
  #3864
muahdib4's Avatar
OHHH...It's an FF02. That might be cool enough. I've never owned one. Yep, I'll have to get one.
muahdib4 is offline
Old 04-18-2007, 12:23 PM
  #3865
I'll be ordering mine on the 21st when they open back up!
Old 04-18-2007, 10:30 PM
  #3866
minimanintaiwan's Avatar
Originally Posted by TENCHO
hello fellow mini racers! i just wanted to tell everyone that i took first place in the Mini A-main this past sunday.
i want to thank MINIMANINTAIWAN for the awesome motors!!!
here's our results....(my real name is jesus)
http://www.hawaiitalks.net/showthread.php?t=8484
You're welcome. Great Job Jesus! Great motor eh? But you must have driven well too! Looked like Keiji almost caught u though
Anyone else like to try these motors $20/each shipped by EMS min order of 2. Western Union only though.
Attached Thumbnails Tamiya mini cooper-img_3339.jpg   Tamiya mini cooper-img_3340.jpg   Tamiya mini cooper-img_3341.jpg   Tamiya mini cooper-img_3338.jpg
minimanintaiwan is offline
Old 04-19-2007, 02:22 AM
  #3867
TENCHO's Avatar
i never thought the FF02 would be re-released! if you were to combine the M-03R with an FF-02, you would have an FFM-05R !!
and an FF-02 for less than 50 bucks! WOW!!! i have extra m-03 parts, so i could totally build another mini for hella cheap!
TENCHO is offline
Old 04-19-2007, 02:27 AM
  #3868
TENCHO's Avatar
Actually it was Manny and Avery i was worried about....but as you can see from the results, they didn't finish the race. I hope next weekends race will be just as exciting!
TENCHO is offline
Old 04-19-2007, 05:23 AM
  #3869
Actually I was mistaken...the kit price is listed as 4200 yen...or about $35!!!!
Old 04-19-2007, 10:04 AM
  #3870
minidriver's Avatar
Must be TCS legal.
The Futaba 9650 is perfect. The servo case is just a bit smaller than a standard servo, so when you go to mount it in an m03, you will need to take a dremel to the servo mounting ear on the tower (the triangular shaped piece that screws on at the top of the servo tower) and expand the length of the slot by about 3 mm towards the cars's centerline - the width of a screw. I don't think anyone can claim that that is not TCS legal (I've been running mine that way for a long time for TCS events). Another suggestion - the servo case ears are not quite as strong as a typical servo, so once in a while after a really bad crash you can crack the case. That is a replaceable part, but often in very short supply - it took me 4 months to get one out of futaba/tower hobbies. Thus when you buy one of these servos, try to pick up an extra case right away. (Of course, now that I have two spare cases in the drawer I haven't cracked it again!) I also use the metal servo mounts from Tamiya that are identical to the plastic mounts - these have long been available back to TA-02 time (sorry, don't have the part number handy).
Finally, make sure that the EPA on your radio is correct so that the servo is not attempting to throw beyond the car's turn angle ability - when you go full lock to one side, the servo should not be flexing the mount, and you should not hear the servo struggling to attempt to turn beyon the alloted throw.
minidriver is offline
