Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-27-2007, 12:59 PM
  #3676
Trader Rating: 27 (100%+)
thanks also what is the diffrence between the model numbers like the MO4M and the MO3L other than bodies
cheesecake is offline
Old 03-27-2007, 01:05 PM
  #3677
muahdib4's Avatar
Most of that will be explained on that website but basically...
M03's are Front-wheel drive
M04's are rear-wheel drive
muahdib4 is offline
Old 03-27-2007, 01:08 PM
  #3678
Tim K's Avatar
Some better pictures of the M03R available:
http://www.tamiya.com/japan/products..._03r/index.htm
Tim K is offline
Old 03-27-2007, 01:15 PM
  #3679
thanks for the help ill look into the forum a bit more and ill probably pick one up after i get the motor for my gas truck
Old 03-27-2007, 01:40 PM
  #3680
ebald1's Avatar
Trader Rating: 42 (100%+)
I was lookin' to get some oil shocks for my M03,do I need the mini or super mini CVA's? I assume the Super Mini are shorter, but will they still work?
Thanks in advance.
ebald1 is offline
Old 03-27-2007, 01:43 PM
  #3681
Manny's Avatar
The super mini CVA shocks will fit just fine.
Manny is offline
Old 03-27-2007, 01:47 PM
  #3682
Steven Key's Avatar
You are correct the super Mini shock are shorter. They are the ones you want they will allow you to get your car lower.
Steven Key is offline
Old 03-27-2007, 01:50 PM
  #3683
TENCHO's Avatar
I have a set of YOKOMO shocks on my M-03. It's not TCS legal, but it's all good! I also have a set of TECH RACING mini shocks....i haven't built those.
TENCHO is offline
Old 03-27-2007, 01:51 PM
  #3684
whould i just buy the mo3r or shoulkd i just buy the regular mo3 is it worth it for the r
Old 03-27-2007, 02:00 PM
  #3685
ebald1's Avatar
good question, and I was thinking the same thing and about to ask the same question. That M03R looks amazing, but I don't race TCS, would it be worth it for bashing? I'm thinkin' I am gonna get to upset when its nice aluminum parts get dinged and scratched from my street.
ebald1 is offline
Old 03-27-2007, 02:22 PM
  #3686
muahdib4's Avatar
I'm on the preorder list and it should be here sometime next week. I'll let you know then (as well as others will too I bet) whether it's worth it. It looks to pretty to bash around though and mine will probably just get built and sit on a shelf...until next carpet season. I'm not running it on asphalt and scratching up all that chrome.
muahdib4 is offline
Old 03-27-2007, 02:29 PM
  #3687
i bought the mini cooper, built it and sprayed the body metallic blue. now i dont wanna play with it...duno if i should sell it. i'll let it go for like 120 if someone wants it...or should i keep it? spread the word for me yall....if not ima just play with it on my local indoor track
topekoms is offline
Old 03-27-2007, 02:57 PM
  #3688
Ken McKinney's Avatar
Does anyone have the instructions on how to build the super mini shocks or where I can download them?
Ken McKinney is offline
Old 03-27-2007, 03:58 PM
  #3689
nagatahawk's Avatar
Default MO4 BUILD
I just finished the build on the Alfa GTA MO4m, looks pretty nice. but I'm gona race it at the TCS qualifier at Tamiya. I added the usual hop ups:
full bearings
alum. front knuckle
hi torgue servo,
r. tow in up right.
cvds,
ball diff
radials/slicks
alum. shocks
blue front, red r springs
novak gt7 esc
and the silver can mabuchi
Here's hoping that Tamiya holds it TCS finals at their Track.
nagatahawk is offline
Old 03-28-2007, 06:20 AM
  #3690
Steven Key's Avatar
I have a Mini shock question.
I am currently running a MO4m with (50746) plastic Super Mini Shocks, 60 weight oil and 2 hole pistons on the rear of my car.
If I change to the Low Friction Aluminum Dampeners (53155) do I need to change the oil weight or number of holes in the piston to get the same dampening?
