Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-13-2015, 09:23 PM
  #23071
Laguna Bozo's Avatar
Default Missing you
Grandpa, nice to hear from you. Bin missing you! Fun race coming up next week. Hope you can make it, at least as spectator. Your table space is still reserved...
Laguna Bozo is offline
Old 03-14-2015, 12:38 AM
  #23072
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by avink007
A close calculation is to multiply the actual speed by the square root of the scale. √12=3.46, 60x3.46=207.6. A mini probably does closer to 20mph, so 20x3.46=69.2mph scale speed. Still a bad crash to hit a wall at close to 70mph!
Oh sure, every time we get all glassy eyed about our stupid toy cars, someone comes along and smacks us down with a fistful of knowledge.
You heard from Bob?! That's fantastic! Very happy to hear that!
monkeyracing is offline
Old 03-14-2015, 04:34 AM
  #23073
sosidge's Avatar
THERE IS NO SUCH THING AS SCALE SPEED.
A RC car is a small vehicle in a normal sized world. Speed is distance over time and an RC car traveling at 20mph is just that. If you made the car bigger, it would still be traveling at 20 mph, because the world (and our concept of time) are a constant.
Forces Related to a crash are solely the forces you would expect from an object of that size and weight traveling at that speed.
sosidge is offline
Old 03-14-2015, 07:05 AM
  #23074
Neils74's Avatar
Originally Posted by Neils74
It is amazing how strong and resiliant these little cars are especially as it would be like us driving a real car into a solid wall at 200mph. That plastic chassis must flex more than we think!
Looks like that a flippant and obviously misguided comment by ME in regards to scale speed causes such a knee jerk reaction within the ranks. Sorry to open the "can of worms"
Neils74 is offline
Old 03-14-2015, 07:14 AM
  #23075
Haha sorry... Back to important things, how is your car setup coming along?
avink007 is offline
Old 03-14-2015, 07:24 AM
  #23076
sakadachi's Avatar
I just know that my silver can is plenty fast for my tiny track!
sakadachi is offline
Old 03-14-2015, 01:27 PM
  #23077
sakadachi's Avatar
Ordered a bunch of maintenance gear today.
Old 03-14-2015, 10:07 PM
  #23078
caltek1's Avatar
Trader Rating: 38 (100%+)
Neils74, I would run a softer compound tyre on the rear. When we run sweeps, 40 or 33 on the front we use sweep 25 on the rear. If the rear end is stepping out then you have too much front grip and not enough rear grip. I only use 300 000 or 400 000 wt oil in my TOP racing oil gear diff.
You can use a harder front spring, softer rear spring, make the car wider at the front and narrower in the rear, (using 6mm hex and spacer on the front and 4 or 5mm hex rear), lessen the rear camber .
You need to try the tyre change first, then these other suggestions.
I have been using Ride Inch ups and decided to run Sweep 33 front and Sweep 25. All I changed on mysetup was my ride height and drove the car a little differently. I changed no settings in my radio and car was still fast and no traction rolling.
I run mwb configuration using the Blitz VWGTI body with no wing. I am currently using the 1 degree alloy bottom plate with 1 degree rear alloy hubs. 5mm hexes all round. 35 wt oil front and rear, three hole pistons. My shocks are built as per m chassis trf instructions. I do not use the droop screws.
I run negative expo on my radio, -25 for steering. I can push my car very hard without traction roll issues.
Anyway, good luck,
Regards,
Calvin
caltek1 is offline
Old 03-15-2015, 07:28 AM
  #23079
sakadachi's Avatar
For me, widening the front will cause more rear stepping out.
If my Rover body had more rear quarter arch clearance, I would widen the rear track...
Old 03-15-2015, 07:49 PM
  #23080
Neils74's Avatar
Anyway, good luck,
Regards,
Calvin
Calvin
Thanks for pointers, the tires will be the first change for sure. In regard to the wider hexes, are these tamiya parts for m or generic parts?
I have read that some prefer stiffer springs at the rear, but I understand the need for softer, especially as there really isn't any weight back there.
The ride height change, especially at the rear already has made a difference, as did a little less camber. I also slowed down the servo speed, It was at default, and it was a fast little bugger.
It's a work in progress, but thanks again for the pointers!
Cheers,
Neilson
Neils74 is offline
Old 03-15-2015, 07:59 PM
  #23081
Heathen's Avatar
Will the 3 Racing M05 gear different work in the M03?
Heathen is offline
Old 03-15-2015, 08:18 PM
  #23082
Nope. Won't fit. Bearing sizes are way off. 03 = 5x10, 05 = 10x15.
Old 03-15-2015, 11:28 PM
  #23083
Hi All
I just started racing my M05 and need some help from some experienced mini racers!
I recently purchased the 3racing gear diff and also the 3racing ball diff for my m05 and I am having the problems stated below
- Gear diff, I cannot seem to get the cushion clips on the stand tamiya driveshafts I keeps snapping them, is there a reason they wont fit? Do I need different driveshafts?
- Ball diff, seems that when I put the driveshaft into the diff side they are not long enough to sit into the wheel carrier and just fall out.
Any help with this would be great!
leeism is offline
Old 03-16-2015, 12:56 AM
  #23084
sosidge's Avatar
With the gear diff, soak the blades in boiling water for a few minutes. This will soften them up and make them easier to fit.
sosidge is offline
Old 03-16-2015, 06:18 AM
  #23085
Heathen's Avatar
What is the best different for the M03? Tried 3 washers and aw grease still not stiff enough.
Heathen is offline
