Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-30-2011, 12:21 PM
  #15571
Zac_with_no_K's Avatar
Originally Posted by mr lee
Tamiya (#50746) C.V.A. Super Mini Shock Unit Set
Thank you!
Zac_with_no_K is offline
Old 08-30-2011, 01:01 PM
  #15572
Will the CVA Super Mini Shocks need spacers on the inside to use short springs or are they made for the short springs?
Old 08-30-2011, 02:41 PM
  #15573
BumFacedGoat's Avatar
Originally Posted by cheapskate.brok
thinking about building extra shocks, but I'm sticking to the clear plastic version. Can't seem to find the shock shafts part number, Any help?
i knew i'd seen it somewhere. this is why no one uses the clear plastic shocks
BumFacedGoat is offline
Old 08-30-2011, 02:45 PM
  #15574
tony gray's Avatar
Read the shock setup part of THIS
tony gray is offline
Old 08-30-2011, 03:45 PM
  #15575
Thank you Tony!
Old 08-30-2011, 04:01 PM
  #15576
YankeeFan123's Avatar
Trader Rating: 72 (100%+)
Which mini body is that in your avatar? Im looking for a new mini body
YankeeFan123 is offline
Old 08-30-2011, 04:27 PM
  #15577
tony gray's Avatar
Team Atlas Suzuki Carry. Pretty much unavailable now anyway.
http://www.rctech.net/forum/5735418-post8951.html
Old 08-30-2011, 04:33 PM
  #15578
If you can find them, whats their price?
Old 08-30-2011, 07:36 PM
  #15579
oh my...
Nway I have yet to break mine Lets just see when it happens, cheers
cheapskate.brok is offline
Old 08-30-2011, 10:27 PM
  #15580
Fluffy622's Avatar
Default HobbyWing 13t 3000kv system
So guys tell me more about the hobbywing systems that you use. Are you running stock spur and pinion? How fast do they go? Have you had any problems with the motor or esc? How do you like the program card? Does it mount up ok? etc....
Thanks ahead of time for any help!
Adam
Fluffy622 is offline
Old 08-30-2011, 10:43 PM
  #15581
cannon's Avatar
Trader Rating: 35 (100%+)
Adam
Adam
This system is perfect for Mini racing
You use the 20t pinion with it .. max out the timing on the program card and away you go. Some guys here have been running their systems for well over two years with no issues whatsoever
cannon is offline
Old 08-31-2011, 02:22 AM
  #15582
Hi guys, i just brought a mo3 mini cooper second hand of ebay. Ive already brought a new shell and some new rims and tyres. What are the best mods to start with?
cheers.
Richy J is offline
Old 08-31-2011, 04:15 AM
  #15583
craypot's Avatar
Adam
As Cannon said the HW is fine. Had mine in for 2 years no probs. The fan doesnt work sometimes but that doesnt seem to matter. I have the ESC stuffed in the rear of an M03 and it copes with the lack of air flow no problems. In Aus we are restricted to the 20t pinion and stock gears for racing. Speed? The good guys can get similar times as 21.5 TC. Program card? Sometimes it doesn't seem to connect but eventually it will and changing settings is simple. The HW works for us as everyone uses the same motor and esc (or the Venom equivalent) with the same gearing and for most racers you never need to replace them as opposed to my 21.5 TC which is on to its 4th motor in 4 months!!!
craypot is offline
Old 08-31-2011, 09:40 AM
  #15584
Fluffy622's Avatar
Thanks for the info and help Cannon and Craypot.
Old 08-31-2011, 03:13 PM
  #15585
I decided to try the mini class of racing, found this M05 pro for sale locally. It came with pretty much every single upgrade Tamiya makes, plus alot of extra tires, used and brand new, a new unpainted Fiat Abarth body, ESC, servo, extra motors, lots of spare parts!
It also came with an extra ball diff, is this a TA03 ball differential?
Jon
evilancer is offline
