Tamiya mini cooper
Tamiya Pre mount tire HELP
Hi guys,
What are the difference between 60D Type A premounts and the 60D S grip premounts?
Do the TCS rules for the Mini class require use of only Tamiya shock springs or are any manufacturer's shock springs legal?
Wondering because I can't quite tell from the rules' verbiage.
TCS Rules:
All Tamiya vehicles must use Tamiya parts only. No parts from other manufactures unless specified within this document.
So, Tamiya springs only. Check and thank you.
You can check the rules, but I am pretty sure you have ti use Tamiya shocks and springs.
Guys, look at this
Tamiya Steel Gear Differential Unit Rear TA06 TA06 PRO FF-03R XV-01 #54471
It's from the XV-01 chassis, reckon they fit into the m05? Visually I'd say yes
R/C Tech Elite Member
Does the XV01 use a 39 tooth differential with the same pitch as the M chassis?
Oh look, would this be an alternative too?
3Racing Gear Differential 39T For 3racing Sakura FF(#SAK-F01)
Nevermind
Jason
Jason
Okay, wrong place, but...who knows anything about the ABC Genetic and basic setup for it? Drop me a PM.
Edit: I looked at that picture again and there are two different assembled diffs... one does look like it could be even made out of steel but that would be madness, what's going on in the pic?
Well the TA06 (and TRF511 w/Upgrade Kit that I'm running) both use the same diff and yes, it's 39t. Whether it's compatible with the M chassis I wouldn't know (it's pretty big!).
i read somewhere in the Australian forum that the Sakura FF diffs indeed fits in the m05 (with a little mod with no futher details). Nways, I am getting one just for curiosity's sake. Let you guys know in 2 weeks
if you are looking for a oil filled gear diff for the m05 cant go past the TOP Sabre FD #PO-SDT114 gear mesh is same as tamiya, and no mods need to be done, expect a few more shims on the outdrives to center it in the chassis
