Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-10-2013, 10:28 PM
  #18556
A 21.5 will absolutely kill a "stock" Silvercan. We have quite a bit of experience with the 21.5 at the Tamiya USA track and it is not an even match. We also have a few that can rework Silvercan motors and here you need a Silvercan that will turn in the vicinity of 21k to make it an even match.
Many of us run 21.5 and the trusty old can and many of the guys here locally run 17.5, 21.5, "stock" Silvercan, and "hot" Silvercans. Personally, I run them all on a regular basis except for 17.5 which I run rarely cause the set up is different and, in my case, is only comfortable with 55mm tires.
Granpa is offline
Old 03-11-2013, 09:47 AM
  #18557
kwkride's Avatar
Originally Posted by Granpa
A 21.5 will absolutely kill a "stock" Silvercan. . . .
We have the opposite experience at our track. A few of the guys switched to 21.5 motors. On the straight, the silver cans just walk away from them. Last week, the silver can that I was running was new, and I didn't do any "break in" to it, just stuck it in the car. They jokingly said that I was cheating by NOT switching to a brushless motor.
We are now agreeing that we will all switch to 21.5s to keep the racing close.
We had this same experience a couple of years ago. We ended up letting guys run 17.5s and then the speeds were almost identical to the silver cans.
Just to clarify this is with "blinky" ESCs.
kwkride is offline
Old 03-11-2013, 02:43 PM
  #18558
Same here, but we do "crank" the timing in excess of 45 degrees. If you don't advance the timing, you're right. The motors don't perform unless the timing is advanced.
Try setting the timing at 50 degrees or so and see what happens. It'll pull the "poop" right out of your shorts.
Granpa is offline
Old 03-11-2013, 03:07 PM
  #18559
GeekSpeed's Avatar
Guys, quick question about tires.
I am running A slicks on all four corners of my M03. I have read elsewhere that these leave something to be desired if you do not have to use Tamiya parts. At the last race, the As seemed to be working OK, but I am new to this, so I don't know how much of an advantage other tires might give me. Any thoughts? I am only looking at 60D, since those are specified by our rules. Thanks.
GeekSpeed is offline
Old 03-11-2013, 03:50 PM
  #18560
Travis S's Avatar
Trader Rating: 46 (100%+)
If anyone is looking for a http://www.rctech.net/forum/r-c-item...amiya-m05.html I just listed mine.
Travis S is offline
Old 03-11-2013, 05:29 PM
  #18561
tiko's Avatar
Trader Rating: 35 (100%+)
Can someone tell me what inserts come with the mini pre-mounted tires I'm talking about the swift gray wheel ones.
Thanks guys
tiko is offline
Old 03-11-2013, 05:48 PM
  #18562
JoeGolf's Avatar
I threw in a circa 1995 540 Johnson (From an old F103L kit), it was well broken in, despite its age the commutator looks to be in pretty good condition (at least from what little bit I can see). Its pretty informal but zipping around the driveway it certainly seems to be noticeably quicker than the Trakpower 21.5 with Novak Club esc combo I ran on the track. The Trakpower is brand new, that was its first outing, mechanical timing was cranked up around 50* (obviously no timing on the blinky esc). Not sure I'll make it to the track this week to get some lap times and do a direct comparison, but we'll see
JoeGolf is offline
Old 03-11-2013, 06:27 PM
  #18563
regarding the 21.5 brushless, alot of it depends on the motor
The best I have found is a Revtech rated @2500kv,
next would be a tekin @2300kv
then a speed passion @2000kv
The track power is very slow. I am sure others have more info, but those 3 motors above are fast.
If i had to use a brushed motor against a brushless I would get a mabuchi torque tuned motor or the tamiya black can motor, as they are about as fast.
the mabuchi torque tuned motor with a 20t pinion has alot of rip out of the corners, more than my 21.5 revtech with a 18t pinion.
Shortbusallstar is offline
Old 03-11-2013, 08:17 PM
  #18564
Look, I am not a B/L motor expert so will tell you what motors and esc that's installed in my B/L Mini. The esc is a KO 350 BLZ and the 21.5 is a Reedy Sonic and the 17.5 is a Novak Ballistic. Most of the other cars at the Tamiya track seem to have the Novak Edge esc. With either motor, it will run rings around any stock Silvercan. The Reedy and the Novak are the most popular motors.
Good stock Silvercans will turn 18.5k to 19.5k at 7.2v. You need one capable of revving 21k to 22k to be competitive with the 21.5. You had better have a 23k or better to beat a 17.5.
Also, some of the old, old Silvercans could really spin up, especially those that had the 4 slots in the can. Many of those would spin up to 21k or better.
Granpa is offline
Old 03-11-2013, 11:25 PM
  #18565
R/C Tech Elite Member
monkeyracing's Avatar
Thanks guys
The S Grip premounts come with hard inserts.
monkeyracing is offline
Old 03-12-2013, 10:28 AM
  #18566
GeekSpeed's Avatar
But, but, what about tires?
What do you guys like in 60D size that are not Tamiya? I hear other brands tend to be grippier than the A slicks I have.
Old 03-12-2013, 01:43 PM
  #18567
I have a pair of A slicks and found them to have plenty of grip on carpet. Don't feel like I need more grip.
Are you running on carpet? Are you using traction compound?
jha07 is offline
Old 03-12-2013, 02:44 PM
  #18568
GeekSpeed's Avatar
I am running on prepped asphalt without compound. They seemed OK to me, but I was wondering if it was worth the cost to try something else.
Old 03-12-2013, 04:40 PM
  #18569
I'd say try traction compound first. That makes a big difference.
jha07 is offline
Old 03-12-2013, 05:39 PM
  #18570
tiko's Avatar
Thank you
tiko is offline
