Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-27-2009, 01:11 PM
  #11086
tony gray's Avatar
Originally Posted by Mini35
Can anybody tell me if this kit comes with bearings, and whether the shell will fit a Xevo chassis? I'm undecided whether to use the M03M Swift or the M05 Abarth as a donor car.
Only the 05 Pro kits come with bearings, the Abarth kit does not. As to whether the shell will fit, well I cant tell you that. I've got someone checking now to find out though.....
Originally Posted by niznai
Does the M05 stock kit come with oil filled shocks? I haven't found a definitive answer on the Tamiya site but it is sort of implied that they don't. Can anyone clear this out?
All the 05 kits (apart from the Pro) come with the latest version of the 'friction damper' They look like normal oil shocks, but they aren't.
Originally Posted by los limbos
Hi,
I have a question, you leave at the M05 the "rollbar" away.
Is this for the weight or to give the chassis more flex.
Thankx Bart
Bart, there are no rollbars available for the 05 yet, that's why no-one uses them.
tony gray is offline
Old 12-27-2009, 01:19 PM
  #11087
Thanks Tony, I've got my fingers crossed that it has enough front clearance to work as for some reason I can't work out I'd really prefer the Abarth to the Swift but the shell will ultimately be the deal breaker, no point buying the Abarth to have to faff about and get a Swift shell later on. It's kind of the same illogical logic I used to justify buying a Buggy Champ.
Mini35 is offline
Old 12-27-2009, 01:25 PM
  #11088
los limbos's Avatar
@ Tony Gray
With the "rollbars" i mean the parts D2 and D3 (numbers from the manual).
Those parts are not always mounted on the pics i saw.
Thats the reason for my question.
Thankx Bart
los limbos is offline
Old 12-27-2009, 01:48 PM
  #11089
tony gray's Avatar
Some people leave them off, some leave them on.
Most racing rules would require that they are left on I would suggest. Certainly ours do.
Old 12-27-2009, 01:56 PM
  #11090
I built mine up with them and when I first ran the car it was twitchy. Removing the rollbars seemed to calm it down and they have stayed off ever since.
Now we have more M05's appearing at our club I find many have them attached and to be honest there's not much in it performance wise.
I guess it's personal preference and you have to admit the chassis does look better without them
shawnh is offline
Old 12-27-2009, 01:57 PM
  #11091
los limbos's Avatar
Tony,thanks for your reply.
Old 12-27-2009, 02:24 PM
  #11092
caltek1's Avatar
Trader Rating: 38 (100%+)
Default FIAT SHELL
The Fiat shell will fit on the Xevo. I have a standard Fiat shell painted and fitted to mine now. I will post pictures after.
Regards,
Calvin.
caltek1 is offline
Old 12-27-2009, 02:52 PM
  #11093
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default 3Racing M-05 front bumper w/ Swift body
Can someone post a picture of the 3Racing M-05 bumper with a Tamiya Suzuki Swift body? I want to see the bottom of the car with the body on for fitment clearance. Thanks!
gtfour93 is offline
Old 12-27-2009, 03:08 PM
  #11094
cannon's Avatar
Trader Rating: 35 (100%+)
Sorry no picture but can assure you that the Swift body fiits over the 3Racing bumper
cannon is offline
Old 12-27-2009, 04:17 PM
  #11095
caltek1's Avatar
Default Fiat Shell and Xevo
Photo's as stated. This car is plenty fast with the 3Racing speed gear spur 33T and a 23 pinion.
I have found the 60D's work on the front and the small Pits on the rear. I will be testing 60D's all round as the basis for TITC testing.
Battery tray is the Atomic tray double sided taped to the chassis, so still allows flex. I am still testing springs and shock lengths. Thank you for the suggestion Greg, works a treat. I do not have any issues with the velcro strap.
Later,
Calvin.
Attached Thumbnails Tamiya mini cooper-dsc02221.jpg   Tamiya mini cooper-dsc02222.jpg   Tamiya mini cooper-dsc02223.jpg   Tamiya mini cooper-dsc02226.jpg   Tamiya mini cooper-dsc02228.jpg
caltek1 is offline
Old 12-27-2009, 05:56 PM
  #11096
Atcom's Avatar
i was wondering if anyone could help me, how change the m04 so 1:10 touring car body fits.
Atcom is offline
Old 12-27-2009, 07:13 PM
  #11097
niznai's Avatar
Is there a dedicated mini TRF shock from Tamiya? I have found on the Tamiya site the shock bodies, and I suppose everything else from the TC shocks would fit, but I would like to know if there's a complete shock kit they offer.
And one more question, does the kit (Abarth) come with M grip tires by any chance? I guess not, but want to be sure.
niznai is offline
Old 12-27-2009, 07:20 PM
  #11098
portyansky's Avatar
Trader Rating: 54 (100%+)
Is there a dedicated mini TRF shock from Tamiya? I have found on the Tamiya site the shock bodies, and I suppose everything else from the TC shocks would fit, but I would like to know if there's a complete shock kitthey offer.
Got a set off of ebay, I submited an offer of $40 and the person took it... http://shop.ebay.com/?_from=R40&_trk...All-Categories
The TC shocks would work as well.
portyansky is offline
Old 12-27-2009, 07:21 PM
  #11099
cannon's Avatar
Try TA54000 .. full set incl 3 pairs of springs
cannon is offline
Old 12-27-2009, 07:27 PM
  #11100
caltek1's Avatar
Arbath comes with standard Tamiya mini tyres. The M grips have to be purchased in pairs the same as the S grips.
The TRF mini shocks are the best if you can afford them or get a set of the 3Racing or Yeah ones. These come in a pack of four and include extra springs as well.
The 3Racing spring set will fit onto the standard TRF shocks. This gives you some more spring choices.
Later,
Calvin.
caltek1 is offline
