Tamiya mini cooper
Getting a little tired of the massive bodyshell choices that you can get for your M03/5 MWB.
Let's see there's the Swift, the Swift and the Swift - Oh and not forgetting the Swift.
Or..maybe the new Tamiya Fiat 500. Or possibly the Speedway Pal Old School Civic Type R
How about this then..
From Ride, a current model Subaru WRX STi. OK, not my favourite car of all time I have to say, but at least it's something different...
I haven't found anyone who has them yet, but according to Ride they are on sale.
M05 Pro
So,,almost have my new mini together,and have noticed that the shocks do not fit very tight using the supplied screws,also the axles have alot of in/out play,,,is this normal??
Craig J,
The excess play on the rear axles can be taken out by using some 0.2 shims. These are available in a shim set from Tamiya or others.
I do not use the screws for mounting shocks. I use Tamiya TRF shocks and these come with supplied ball studs and spacers. The screws will work also as they will let the shock end move.
If you are using the supplied clear shocks beware they are brittle and will not survive a major impact. Tamiya Super mini CVA's or 3Racing shocks are also acceptable. If you use the 3Racing shocks ensure they are full of oil. It would be a good idea to drain the oil and redo with 30/40 or 50 weight oil. Depending on your racing surface.
Have you visited this site? http://www.rc-mini.net/joomla/index.php
Regards,
Calvin.
Regards,
Calvin.
Craig J,
This slop is normal for a Tamiya kit. Some people shim them up, others don't bother and are just as fast.
Tamiya sell their own packs of various shims.......
Cannon, you'd better send a couple of those Subie ram-raiders Windsor way when you get them in.
They are fully siik bro'.....
Fleety.
Fleety.
Craig J,
The alloy 1.5 degree rear hubs on the MO5 Pro kit have a lot more play,(side to side movement) than the standard kit 2 degree rear hubs. The shimming of these is better for the bearings, just remember not to place in too many shims otherwise the axle will be tight when you mount the wheel hub, wheel and tighten. The best is to add one or two shims reassemble and then mount wheel and then check for movement, keep going until acceptable.
The standard kit parts are normally not that loose. I should have included this in my explanation.
Regards,
Calvin.
Regards,
Calvin.
I picked up my Christmas present for my M05- the Tamiya ball diff !!
Looking forward to trying it out in a couple of weeks,when I return to the track.
I now only need some new rear body posts for the lwb Cooper shell....
tamiya m03
do anyone know how to get the rear end of the mini to grip in the wet when using standard tamiya radial tyre pls
please email back on [email protected] if pos pls as sometimes can't find replys on forum
Does the M05 stock kit come with oil filled shocks? I haven't found a definitive answer on the Tamiya site but it is sort of implied that they don't. Can anyone clear this out?
I think only the M05 Pro comes with the plastic oil filled shocks.
buy a standard kit and the TRF dampers
add 5mm spacers inside the shocks and 500 oil in it and you got a sorted mini
Mo5 help
Hi, i've just gotta Mo5 and need abit of help
the servo saver that comes with the kit is rubbish, so I would like to know if this one will fit it? http://www.ardentracing.com/shop/acc...rvo-saver.html
thanks, Joe
thanks, Joe
M05 Abarth Asseto Corse question
Can anybody tell me if this kit comes with bearings, and whether the shell will fit a Xevo chassis? I'm undecided whether to use the M03M Swift or the M05 Abarth as a donor car.
The Swift is attractive as I've been told it comes with bearings and the Swift shell will fit the Xevo chassis according to rc-mini.net, plus I can use the leftovers as spares for my beater M03 SWB Cooper. Plus, it's $20 cheaper.
However, the Abarth has IMHO a nicer shell and comes with the newer ESC which I can use in my '03 or sell on, plus I can sell the leftovers pretty easy to guys at the club who run '05s, to recoup a lot of the extra cost over the Swift.
I guess what I'm trying to say is I can't decide for myself, so I need some help.
Hi,
I have a question, you leave at the M05 the "rollbar" away.
Is this for the weight or to give the chassis more flex.
Thanx Bart
Can anyone help me with this?
Thankx Bart
Thanx Bart
Thankx Bart
thanks, Joe
thanks, Joe
