Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-18-2013, 09:59 PM
  #18601
R/C Tech Elite Member
monkeyracing's Avatar
Weird. I posted this earlier, but it disappeared. So...if you look on the 3Racing site, all of the rebuild parts, including the case for the M05/06 oil filled diff, are Sakura part numbers. Bingo dingo! Look at the bottom of the page.
monkeyracing is offline
Old 03-18-2013, 10:35 PM
  #18602
VooDooPH's Avatar
Trader Rating: 18 (100%+)
TA06 diff wont fit in a mini... they're of different size and pitch...
VooDooPH is offline
Old 03-18-2013, 10:42 PM
  #18603
VooDooPH's Avatar
Originally Posted by djmcnz
Edit: I looked at that picture again and there are two different assembled diffs... one does look like it could be even made out of steel but that would be madness, what's going on in the pic?
The narrower one is a spool made for the XV01TC
VooDooPH is offline
Old 03-19-2013, 03:03 AM
  #18604
sosidge's Avatar
Originally Posted by cheapskate.brok
i read somewhere in the Australian forum that the Sakura FF diffs indeed fits in the m05 (with a little mod with no futher details). Nways, I am getting one just for curiosity's sake. Let you guys know in 2 weeks
There is no point buying the Sakura FF diff as it is basically the same as the 3Racing M06 (M05) diff but in a case that won't fit the Tamiya Mini.
The 3Racing diff works fine in a Mini as long as you run it in A LOT. The standard seals are badly sized and need a lot of breaking in. Locally we've found that a well sorted gear diff is always faster than a ball diff by a couple of tenths a lap.
sosidge is offline
Old 03-19-2013, 04:16 AM
  #18605
TonyD.'s Avatar
Trader Rating: 44 (100%+)
The TA-03 ball diff will fit.
TonyD. is offline
Old 03-19-2013, 12:03 PM
  #18606
ruebiracer's Avatar
Questions were about gear diffs.
Spec-R has also gear diffs for M05/06.
I have 2 3-Racing ones in my M05 RA and my M06 Pro,
and Im really happy with them. Especially on my M06, where the diff has already done 6 Races and practice without leaking or any trouble.
The blades make it perfect. I hope 3-Racing will restock these.
Maybe I will also order a Spec-R diff for my other M06 this season.
BR,
Matthias
ruebiracer is offline
Old 03-19-2013, 12:18 PM
  #18607
TonyD.'s Avatar
BR,
Matthias
My bad was just trying ot help.
TonyD. is offline
Old 03-19-2013, 12:27 PM
  #18608
ruebiracer's Avatar
Diff carrier with 39T is the same for Sakura and M05/06,
the side plate is specially made for the Ms from alloy and a special spacer for the other side.
Br,
Matthias
Old 03-19-2013, 12:43 PM
  #18609
Thanks guys! Most online stores I went had them out of stock (well, the proper M-06 ones from 3racing) hence my search. Cheers to all
cheapskate.brok is offline
Old 03-20-2013, 09:13 PM
  #18610
Trader Rating: 72 (100%+)
So, to stay TCS-legal, one must run Tamiya springs.
I'll be running the Tamiya PN 54000 aluminum shocks in an M05, mostly on asphalt.
Which Tamiya spring kit is the best one to get?
waswadener is offline
Old 03-21-2013, 01:51 AM
  #18611
marcos graveyar's Avatar
Tamiya 53333 Short Spring Set.
marcos graveyar is offline
Old 03-21-2013, 05:55 AM
  #18612
What exactly do you mean by a well sorted gear diff?
I run an M03 and for several years I ran the Tamiya ball diff. Everyone was telling me the ball diffs strip, but I never had a problem. Until, that is, I went to the TCS race in New Jersey. Sure enough in practice my car stopped moving. I ws fortunate that another racer had a fully set up gear diff for an M03 and didn't need it because he was running an M05. Well racing season will be here soon and I want to go through the car, but I don't want to mess up the diff. Any suggestions?
jiml is offline
Old 03-21-2013, 10:41 AM
  #18613
sosidge's Avatar
By gear diff I meant oil-filled gear diffs, the Tamiya kit "open" gear diff is a completely different kettle of fish.
sosidge is offline
Old 03-21-2013, 12:23 PM
  #18614
Oh, okay
jiml is offline
Old 03-21-2013, 12:56 PM
  #18615
Pretty much on the money. We do have a guy running locally who's very fast with a ball diff, but it's very notchy and he's an incredibly good driver. Oil filled diffs, spools and locked up stock diffs are the order of the day for everyone here.
An odd effect of the tighter diffs is that RWD cars have been knocked almost completely out of contention. Once the problem of getting the power down in the FWD cars was sorted, that was it. Also, the M06 is an over-engineered, fragile, turd of a car. (M04 still rocks.)
