Tamiya mini cooper
R/C Tech Elite Member
Those Gens Ace batteries are good. Don't believe anyone who tells you that you need some kind of super 70c batt. It's a mini and 99% of the time, these will do the trick.
Jim
our club only runs them bone stock with the 540 motors, even the stock friction springs with the inards pulled to free up the shaft. and no chassis mods, so I cant trim the battery mount.
Gen's ace's are great and 25c is plenty of punch for the silver can motor.
We can run any length chassis or any body, and any tire.
so now I have another question. With a stock motor and lack of brushless power, should I worry about weight? Should I run the lightest battery I can. a 2400 can make a 6 min main and is 172g, 3000 213g, 4000 244g.
Its only a 2oz difference between 2400 and 4000. is the weight going to hurt the acceleration and help the handling?
We've got one. I'm just too A) lazy and B) crippled to get there. Besides, that fuzz is from the other club we've been sharing a track with. They've got the 'real' RC carpet. We use cheap, low pile office carpeting. It's cheaper, more durable and less fuzzy.
Jim
Jim
Wish the GenAce have a plug in stick pack. Trying to get rid of body bulge. (car body)
A 2400mah lipo should last you through a 6 minute main. Two mains if you want to push it. Depending on how hard you drive, it might start dogging towards the 12 minute mark.
Are you allowed to add weight to the car? A little lead on the front end of a mini can do wonders for cornering.
As for my hairy car, I usually use a brush between rounds. Works just as well and not nearly as noisy. I just didn't brush it off after busting my car last Tuesday. My car's usually cleaner. Honest!
jim
I forgot to ask about the bearings, they just said no chassis mods when I was going to trim for the battery. But if I can change or modify the shocks and tires then I realy dont think bearings are a chassis mod.
I will ask before i get one which probably wont be until the end of the month. By then I should have all my ducks in a row.
THat is bit odd rule, no bearing?
Tamiya 54000 Shocks
Hi
Running Tamiya 54000 shocks on my mini
Anyone know the part numbers for the individual bits :-
Shock shafts
Seals
Plastic Parts ect
Bound to break something soon want to be able to fix trackside though.
Shock shafts
Seals
Plastic Parts ect
Parts code
53334....... Low Friction Damper V Parts (2 pcs.)
9808169... Damper Cylinder (2 pcs.)
9808170... Piston Rod (2 pcs.)
9808171... Coil Spring (Medium, White, 2 pcs.)
9808172... Coil Spring (Hard, White, 2 pcs.)
53333....... Touring Car Tuned Spring (Short) (2 pcs.)
53572....... TRF Damper Piston (2-Hole, 4 pcs.)
53573....... TRF Damper Piston (3-Hole, 4 pcs.)
53574....... TRF Damper Rod Guide & O-ring Set (4 pcs.)
53576....... TRF Damper Oil Seal (4 pcs.)
53577....... TRF Damper Urethane Bushing (10 pcs.)
9804153... 3x2mm Spacer (10 pcs.)
9805611... 5x9mm Ball Connector (5 pcs.)
9804205... 5mm Ball Connector (4 pcs.)
9805240... 3mm O-ring (7 pcs.)
9808077... 2mm Shaft Guide (4 pcs.)
50588....... 2mm E-ring (15 pcs.)
Might have to use 54044 Ti shaft if you can't get 9808170
Thanks to some earlier advice on this forum I had my MO3 on the track for the first time. It ran well and was great fun. It has a gear diff (new experience for me) and is short wheelbase. i notced there is a ball diff available. Is it a worthwhile change.
Thanks, Chuck
Thanks, Chuck
Hey Sydewynder,
Great info thanks for the quick response.
Personally I favour the 3Racing gear diff with #5K oil at the moment, indoors and out. I don't like the "open" kit diff or psuedo-spools. M-05 ball diff builds quite free, probably a bit too free for most tracks, TA-03 ball diff builds quite tight, good for most tracks. There are many build "tricks" to get a diff that is stiffer than the intended action (grease/shims etc). I would avoid the 3Racing ball diff, not reliable.
I wouldn't be in a huge rush to buy replacement bits. I've yet to see anyone break anything on those shocks - ever.
I'm sure people have but it's very, very rare...
Only thing I've ever seen is the bottom plastic eye get worn from hitting the ground on a bumpy track with a low car.
Shockshaft guide is also something i would check, they go oval over tme.
See if the shocks have sideways movement on shaft. Due to lack of replacements i used normal pistons once from clear shocks and double o-rings in seal, could not tell any difference on track.
Most racers at my track has done same, can be just us, we race indoors carpet with high grip with 13T ezruns. Tires is foams from Xpress, 26 shore and 30 shore, free choice. I run my car with 30 front and 26 rear. Might be the tires put more load on dampers.
Also i put Paragon on mine.....
