Hpi Pro 4
Originally Posted by Proteus
I'm one of the few that had the pro4 at the track. Your taking about the Colliseum, right? I took a break this summer but when I get a chance I'll find my setup sheet for that track. Sorex 36's and RP 30's worked real well. What class are you gonna run?
thanks
Steve
Originally Posted by josh69162
I used a 35 tooth for a stocker, but the manual has gear ratios for the motor turns. As for the front drivetrain, the only thing I can think of is play with the shims, and grease the gears. Greasing really helps a ton. By spinning the input shaft I get a second or two of spin. If it is shimmed too tight, or will be very loud, and won't spin. I have no shims on the rear input shaft, and I am gonna take apart the front and reshim everything when I clean it. Other than those two things, you shouldn't have any problems.
-Josh
-Josh
thanks again
I don't want to come across as a "nay sayer" but I just got back from my local track with my new pro4 and was done in 30sec.s. Maybe I just recieved a bad quality control car or something, I was driving the car around a Hairpin turn( Not much speed needed for hairpins) ran the front inside tire over the dot and the front A arm was broke in 2 not to mention bending the MIP cvd!!! As posted above I had problems with the gears meshing correctly. To boot none of the local shops carry HPI parts and I have less than a week to fix this...Is there some sort of new composite arms that I need to get?? Thats a pretty soft arm to break under force(no contact with anything).. Again I am not normally like this but A $350 car should not be that brittle!!
you really like the flaming smiley..
Wahhh my hobby shop doesn’t have parts... Wahh my car broke when i crashed
Originally Posted by Antonio Sabato
I recommend you sell your Pro4...and get a SAVAGE.... the pro 4 is a race car! Every race car i have ever owned is brittle.
EAT ME
Tech Legend
Trader Rating: 51 (100%+)
The only cars that are tough in the a arm department is any of the Tamiya cars running the 04 type system. The stock 415, Surikan EVO3 and the TA04 come to mind.
I have broken many arms on many brand cars. The less flex the more breakage.
I think HPI did have some stronger A arms out that are not near as stiff but I don't know the part number.
I only needed to vent, I have been racing for about 18 years now and have never experienced a car that reacted like that! The other guys I race with that that was odd for such slow speed and no contact to have that happen. Like I said maybe that batch of moulded arms was already doomed!
what did you hit I can't beleve you just hit a dot and broke a arm I have never broken anything but a cvd and that was just from ware. Friday night I hit a car at full song on the straight and tumbled about 20 time car landed on it's wheels and just drove away to finish third no broken parts no tweek no nothing this car just does not break period!!!!!!!
Trader Rating: 22 (100%+)
get rid of the MIP shafts and get the steel ones you can try these arms
31420 PRO4 HIGHT TRACTION SUSPENSION ARM SET(2 PCS)
75184 PRO4 HARD STEEL UNIVERSAL DOGBONE(2PCS)
Thats the freakiness of this whole thing, I didn't hit anything!! Better to have happen now than in the Show!
for the Dog bones... stay with the MIPS and get TC3 steel dogbones... or TC4 HD dog bones. they are a direct fit... with the hard steel universals...again..only available overseas... TC3/TC4 bones are readily available at majority of Hobby shops.
to order overseas.. Try RainbowTen in Japan... they have everything you can imagin. or RcModel in HK too...
That has to be the most bizzarre story I've ever heard! I had bad glitching one day, I sent my car flipping over the barrier after a direct hit on the front right a-arm. I bent a hingpin, snapped a ball stud, ripped the knuckle in two, but my a-arm was fine! I think you definately caught a stroke of (extremely) bad luck. The bad part was I had spare arms, but no spare knuckles...
-Josh
EDIT: As for the bones, I have blue TC3 bones in the front, and composites in the back. It is a very strong set up it seems...
-Josh
-Josh
-Josh
Well guys, I haven't posted in about 150 pages, but I'm back. I got the chance to own another Pro4 and I went for it. Car should be at my house this week.
Congratulations! What made you come back?
-Josh
-Josh
