Hpi Pro 4
Thanks for the help and ideas guys. It's not the pinion or spur, I have changed several times to make sure it wasn't. I had the pin slipping in my CVDs and fixed it a while back with shoogoo and fiber reinforced tape at the loss of a aluminium front knuckle. I have tore down the car several times. Checked the shims ,gears , driveshaft and anything else I could think of. I think it is either one of two things the front bevel gear is slipping under load (like BritRacer said) or I have mismatched 1.0 version gears and 1.1 version gears . I just can't pinpoint it at all. Thanks for the help but it looks like I am going to have to throw some money at it and see if that helps.
I don't think that mismatching the gears would have anything to do with it. They are both the same size and stuff, the only difference is the material strength. But there could be some variable I don't know about that would make a difference. Can you tell what region the click is coming from?
-Josh
-Josh
It consistantly comes from the front whether it is a spool ,diff or one way while under braking or accleration only. It's getting on my nerve
Trader Rating: 22 (100%+)
What version gears are you running? Sounds like you havent meshed the gears properly.
"also my car has a slight but of understeer at the moment
can any1 recommend how i can make it better without spending anything on it, ps i dont have a spring set...?"
surly sumbody can answer my simple question... please lol
im on 0 already tho
Try going back to the 4 degree C-hubs and swap the springs around to silver on the front and gold on the back. Or you could remove some of the spacers on the inner front camber link, this roll centre change will give the front end more grip. Remove the front roll bar. Swap the 2.5degree and 3.0degree pivot blocks from the back to the front. TBH though the standard Pro4 setup did not understeer for me, maybe you should think about trying different tyres first?? Jonathan
What he said..
my setup isnt entiery stock and i cant change the front c-hub from 0 degree because ive got some homemade 1's which i wanta keep using...
however i could try changing the springs so that the silvers on the front, will this work then? and the pivot blocks thing i will also try thanks.
ive got about 0 toe now so should i try putting some toe in on then?
i race carpet foam by the way...
The version 1.1 gears diff slightly to the first version gears. First of all the small gear is backed with plastic, and the larger gear has a "step" to it on the back whereas the older gear just gradually goes inwards.
what the correct way to get hpi shock to perform right
hey what a proper way to bleed the shock to get the right amount of bleed/ and rebound a little diffrernt than ae shocks
