Serpent to 1/10th EP Touring Kit S400
#2251
good luck to u randy n billy.....bring d glory to serpent!
guys, wat other cvd axle tat can fit s400 ??
where can i find rear yokomo rear diff tat can fit s400 ???
wat else i need in-order to use yokomo rear diff in s400 ? diff ring ? bearing ?
thanks
thanks
#2254
Randy did well!! He is consistant. Finished 6th @ Reedy two weeks ago. Finished 7th overall at the Nationals.
Good job Randy!!!
Good job Randy!!!
#2256
R/C Tech Elite Member
Finally back from the nats after a full day of delayed flights yesterday. Billy and my cars were both awesome, but to put it lightly, I don't think either of us have ever had such bad luck in the mains. Billy didn't get to finish even 1 main due to fluke luck, and in both classes I only managed to finish 1 of the 3 mains.
I learned a ton about the car this past week though, so despite the pretty bad finishing positions in my mains, I am definately glad I was there. I definately had a car that was capable of a top 5 finish in modified, and in super stock I had a car that was capable of the win. The S400 was once again dialed.
#2258
Thanks!
My setup changed a ton for this race, it is much more aggressive with quite a bit less traction than the previous setups, this track had some very high speed areas that lead into hairpin turns, so I basically had to make the car turn on a dime.
I don't think I've seen Billy run the same setup twice, he is always tweaking and trying to improve his car. I am quite opposite of that, I make a lot of changes at 1 time to the car to try to get the feel I want, and then I tune my driving to that setup.
#2259
#2263
Randy,
Another great show for the S400... If you get a chance can you post your newest 19t setup for us all to have a look at? Cheers.
