Serpent to 1/10th EP Touring Kit S400 >
Old 10-08-2011, 03:42 PM
  #3286
Trader Rating: 68 (100%+)
Is anyone out there looking for the S400 motherload because I have it. At least three complete cars including a carpet chassis foam car lol. Gear diffs, balls diffs, shocks, everything including lions tigers and bears oh my. Multiples of everything. not looking to part out though. lmk if anyone is interested by pm. thanks
todb is offline
Old 10-10-2011, 03:03 AM
  #3287
Hi,first let me say that I'm new to the electric TC,been running Nitro since almost ten years and now got a nice deal for a S400.Is there anything I should look out?The car comes with spares,but I usually don't crash.What do I need to run lipo?Thanks.
30Tooth is offline
Old 12-27-2011, 09:13 AM
  #3288
adidasink's Avatar
Trader Rating: 29 (100%+)
I am thinking about getting rid of my S400....I have 2 of them...one is purely for parts....enough for almost 2 complete cars. Is there any interest in anyone wanting these?
adidasink is offline
Old 01-03-2012, 08:21 AM
  #3289
adidasink's Avatar
I just put my 2 S400's up on the For Sale section.
Old 09-09-2012, 11:11 AM
  #3290
My s400 and it's recent mods.
- Exotek top deck
- diff are flipped
- servo is flipped inboard
- reciever moved to the outer edge since it is lower weight.
- Lipo pushed as far inboard as I can, to bring the weight in.
10.5 boosted and runs on a small technical tarmac track.
not enough posts to add some photo apparently, will add pics when I can.......
gerg is offline
Old 09-09-2012, 11:13 AM
  #3291
pictures in my profile if anyone interested.
That's one more post.........
gerg is offline
Old 03-25-2013, 07:13 PM
  #3292
Is anyone looking for S400 chassis's. Just the chassis though not a roller. I have five of them that i found in my closet lol. one is slightly used, one is new but out of package, one is nip, one is the 3.5 carpet chassis. Also one has the front bulkheads, shocktower, frt and rear belts, motor mount, center shaft with gears and the rear bulkheads. this chassis has some marks on it as well. I just thought someone might want them. pm me here or send email to [email protected] thanks
todb is offline
Old 04-16-2013, 12:27 PM
  #3293
Default HI! Please Help ME Gergely
Hi Gergely...please help me for the info to Serpent S400. Please check my request that I wrote on the forum section Electric On-Road.
Thankssssssssss
Bye
Alessandro
Aroplanino is offline
Old 04-22-2013, 06:15 AM
  #3294
Thankssssssssss
Bye
Alessandro
If you have question about s400, you should re-post it here. I will help of I can, I made many modification and I need to take some more photo and update this thread as well.
gerg is offline
Old 05-16-2013, 07:04 AM
  #3295
Timbo99's Avatar
Trader Rating: 14 (94%+)
Default 2 for sale
Hi,
I have 2 s400 complete cars with alloy hop-ups and spares,and I don't use them anymore.
Contact me if you would like to buy them.
[email protected]
Thanks,
Tim
Timbo99 is offline
Old 05-31-2013, 01:48 PM
  #3296
OK, so here are the pictures of the first stage of modifications to my S400 as mentioned further up on this page.
gerg is offline
  #3297
I later made some more modifications by adding gear diff's from Tamiya 416 in front and rear.
For me to get them to fit, I needed to use different belts because the 416 gear diff is larger.
Original S400 has 35t diff pulley and 16t centre pulley.
My modified S400 has 37t Tamiya Gear Diff, and 18t centre pulleys.
The 18t centre pulley are from 3racing 3PY/18.
Original S400 belts are 177mm / 59t rear, and 501 / 167t front.
New belts used are Xray 305444 183mm / 61t rear, and Cyclone HB 70738 507mm / 169t front.
I also need to use a lot of shims because the new diffs are narrower than the S400 blocks. Especially on the front it was difficult, and you can see shims in the photo and also how far the bearing is out of the bearing holder (I have shim inside the bearing holder too).
I enjoyed modifying the S400, and I was reasonably competitive with it. It seemed to be a very solid car and I did not break many parts. However I decided to retire it and bought a S411 2.0, so this chassis is no longer being run regularly. I have a lot of parts for it though and I think I might set it up for stock class if I every want to run in anouther class.
Cheers.
gerg is offline
