Serpent to 1/10th EP Touring Kit S400
#2266
R/C Tech Elite Member
Thanks!
Honestly I wasn't going to bother posting the setup, the track was so bumpy and had so many straightaways into hairpin turns that I really don't think it's much use to anyone, it would probably just do donuts on a normal track because of how little traction it has.
#2269
hi guys, i notice almost everyone is using mazda 6 or speed 6 in big race now.. i notice speed 6 is giving very much steering which nt suitable for low traction track...any comment on mazda 6 ??
randy, wat your comment bout the 4600 SHO battery ??
i still wondering wat other rear diff tat can fit into s400.....
#2271
I've run the 4600SHO at the Reedy Race and the ROAR Nats and they were great at both events, lots of voltage with a ton of runtime left at the end of my runs. At the Nats we wanted to test to see if a motor/gearing combo could overheat my ESC and we finally pulled it off at 8 mins of running.
#2272
I did finally get up to BCR for some racing today. The layout was a bit, um different. Small track to start with and the layout didn't have a full straightaway on it so it was pretty interesting running a 3.5 Orion. But the car was good. I choked in qualifying and ended up in the B. I was fighting for the lead and choked again. Oh well. The car was great. I was running Randy's setup except with the wider (stock) pivot blocks. I think I could have used a little less rear toe because the rear tires were getting a bit hot after about 3 minutes and loosing some rear grip. But overall the car was great. I'm happy with the way it's running.
#2273
So far, on every track I have used the Mazdaspeed 6 on it has had less steering than the Mazda 6. If you need more traction just mount the wing further back.
randy, isnt it illegal to mount the wing more further back ??
#2275
ROAR and IFMAR is basically the same. IFMAR dosen't allow Lipo's yet.
#2278
where have gear diff onsale ?
#2279
