Yokomo MR-4TC SD
#1561
MO told me how to make a spool and i made one for the main but i used my own sandpapper and it made a big differnce. THANKS MO! see you guys this weekend
#1564
I have another alternative for CVDs...the Hardened cvds from the MR4TC will fit....front and rear...the front bones are about 3-4mm longer than the stockers, but since the stock ones were only about 3mm inside the outdrive it still is only about half the way into the outdrive....everything fits perfect...and they seem to weigh slightly less than the stockers...not aluminum light..but much stronger.
#1569
Mo
you got a PM...
#1570
the spool feels good but im going try the one way on friday
#1571
Anyone notice that the Black SD will be available in Japan at the end of this month? Just curious. Anyways, ran my SD again today. Felt pretty good. But still didn't try the rear shock deal yet. I might this weekend. I'm too comfortable with my setup right now to change it. But I guess that's the only way to get the most out of my car is to try different setups and different things. Blah blah blah, let me head out...
#1573
Hi Guys,
We should have the one-ways and the center graphite shaft in stock soon (Tomorrow or Friday). Also, we have the Rayspeed springs coming in as well. There are four tensions. I'm also working on bringing in hop-ups from Japan for the MR-4TCSD, I'll keep you guys posted
Steve Wang
Steve Wang
#1575
one-way parts
Hi guys,
I´ve just browsed through the SD parts list.... What is part SD-641T (One-way
housing) for? Is it just a spare part for the one way 640T or do I need both parts when using a one-way.
Thanks!
IH
Thanks!
IH
