Yokomo MR-4TC SD
#1593
Hi guys. Greetings from Malta.
I have seen Masami's writings on the Yoke USA forum.
What can we do to entice him to help us out with our Yokes on this one.
From what I have seen of Masami, and his dad, they don't talk much, but what they say makes alot of sense. he would be a real asset to this thread.
This week I am concentrating on improving my son's TC3 a bit so I won't be doing much running with the SD. I drove his championship winning TC3 yesterday. It understeers into corners like crazy. I don't know how he manages to drive it as fast as he does. I'm sure he will be plenty quicker by the time I have finished with it.
regards
Joe from sunny Malta.
regards
#1594
There is another way - wire up the fan with a power plug for your receiver and plug it into the third channel (assuming you have a three channel receiver). This works extremely well.
Originally posted by johnbull
Hi guys. greetings from Malta.
Just been catching up on the last 24 hours on this fast thread. Well done and keep it up. it's all so helpful.
RANDMAN. To try to answer your questions.
FAN. I use a small 12 volt computer fan. If you can find a 5 volt one it will be better, and I know they are around. Just haven't been able to locate more than 1. That one is fitted to my belt drive MR4. Another thing to look out for is as low a wattage or amperage as possible.
As far as battery drain is concerned I can tell you that I fitted a similar 12 volt fan on my son's TC3. He runs 9 and 10 turn motors in 5 minute mod races with 3000 cells - and still gets plenty of duration and speed. The fan's consumption is negligible.
As far as connecting the fan is concerned, there are a number of ways you can do it. I just went straight onto the red and black lugs on the Novak GT7 speedo. This means that the fan is on when the cells are connected. I don't like the idea od hard soldering my cells. Instead I use good quality Corally gold connectors for all my cells, and I don't think I loose much in terms of resistance. If you solder your cells in then pass one of the fan wires through the speedo switch but check whether the switch is on the pos or the neg side. I can't remember offhand. The last alternative is on the motor wires but as you say that means your fan only works with the throttle.
#1595
Hi...
Was thinking of purchasing an SD and wanted to get everything in one fell swoop... has anyone tried any hop-ups from:
Square (titanium axles etc.)
Tobee Craft (lite alu driveshaft, alu dogbones etc.)
Any other tips on what to buy aside from the breakables would be great!
Thanks guys!
Thanks guys!
#1596
Originally posted by jwwu
Hi...
Thanks guys!
Hi...
Thanks guys!
#1597
Hi Guys,
We are working on the Tobee Craft stuff, and the price should be lower than Japanese MSRP I'll let you guys know when we receive the parts in stock.
Steve Wang
Steve Wang
#1599
Originally posted by Randman
Steve - Did you guys get the carbon shaft, and 1 way?
#1600
Hi Guys,
Yup, they are in stock (but going very fast!) Both the one-way and the graphite shafts are in stock. We also have some MMS back in stock and the Rayspeed Springs too.
Steve Wang
Steve Wang
#1601
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Hi Guys,
Steve Wang
Steve...
Can't find them on your website...
I want to order 2 set each of Rayspeed springs Red and White.
I'll email you too...
#1605
it can tell you the no load RPM, amp draw, and condition of the motor. It's not as usefull and an actual dyno but it's better than using the "ear" method of determining which motor is faster. You can also use it to break in motors and run a lathe and it's alot cheaper than a dyno
