Yokomo MR-4TC SD
#1442
johnbull - geometry changes to free up the back end on power - I would try (in no particular order)...
Less rear toe.
Raised rear roll centre - requires the fitting of spacers (2mm is biggest that will fit) under balljoint on rear hub, or raising the inner wishbone mounts by 1mm or more, or a combination of both.
More rear anti-squat.
Less rear toe.
#1445
i dont think Komkit knows... He's waiting for me to come indoors to get him a carpet setup for the SD..
#1446
Originally posted by mo
Sounds like you may be too soft and the the body or chassis is hitting the carpet since it is just high speed corners. I would try going up a spring or 2. What are you running now?
It's made the sound with out the body on it as well.
Here is my
SETUP SHEET
#1447
If I wait for you to come indoor....ummm RUNNING your car at all for that mater... I will have to wait until I am 100 year old.. Don't make me go there
#1448
I should have all my stuff from Yokomo by firday..the oneway is what was holding me up.... 5 long days of shopping :-(
then i will be ever where racing it, getting ready for the nats.
#1449
I'm going to get another kit for mimis cause its raining ever weekend so i guess i should be getting a foam setup ready for this winter..
#1450
R/C Tech Founder
On the leaky shock issue: When you are building shocks, I can't stress enough that you need to lubricate both your shock shaft and the o-rings before you put the shaft through o-rings. I bet that 90% of leaky shocks occur because that was not done beforehand. The o-rings have a tight, tight fit around the shaft, and they *will* be damaged if the shaft does not go smoothly through them.
If you're not sure if that's the problem, just pick up some new o-rings and rebuild the shocks. They are super cheap.
#1451
Komkit, are you running you dual rate (steering throw) at max.? If so, the wheels will chatter after the universal gets to a certain angle. Try turning your steering down to about 80%.
I won't be able to post much more today or the rest of the week. I'll be leaving in about 4 hours for the Reedy Race and probably won't have computer access until I get back on Monday.
#1452
Errr not so sure about dual rate.. I kind of thought about the ackerman thing a little while ago.. I'll look into that later this weekend... Do me no good to do this kind of thing on the bench.
Man, no computer no Internet for a week? hahahaha Wireless PDA is the answer
#1453
R/C Tech Founder
My notebook can hook up with my cell phone for wireless internet anywhere I go. Makes race coverage easier when I'm at the track for big events.
