Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 01-02-2009, 05:42 PM
  #8236
Trader Rating: 49 (100%+)
Originally Posted by quietstorm76
I'm running 64 pitch 100/41 for 4.78fdr
what 64 pitch spur works?
cleblanc is offline
Old 01-02-2009, 06:14 PM
  #8237
trdsupra88's Avatar
Trader Rating: 25 (100%+)
I had a FDR of 8.15 on the smalll track I run on with my tc4, would it be wise to try to acheive the same ratio with the tc5?
trdsupra88 is offline
Old 01-02-2009, 06:23 PM
  #8238
mr crum's Avatar
u must b runnin mod mot for a fdr that low but to answer ur question it will b easier to get that fdr with tc5 cause internal drive is 2.0 compared to the tc4 is 2.5
mr crum is offline
Old 01-02-2009, 06:39 PM
  #8239
Maybell's Avatar
Originally Posted by AdrianM
BMI Racing (www.bmiracing.com) sell pinions from 45T to 60T in 64p
They are machined aluminum plated with a special nickle/teflon coating. Very hard and slick.
Nice lookn product Adrian!
..but I have a challenge for you! For 12th and WGT...
Please make us some small spurs for brushless that allow us to have a smooth diff...as smooth as with a Kimbrough gear that is...
Pretty Please!!!
Maybell is offline
  #8240
trdsupra88's Avatar
I run stock on a very small track. The lap times are generally 7-9 seconds...
Old 01-02-2009, 06:46 PM
  #8241
AdrianM's Avatar
Originally Posted by Maybell
Nice lookn product Jason!
Pretty Please!!!
Ask and ye shall recieve. This gear is machined from acytel, takes 12 diff balls, is WAY harder to strip than a Kimborough and is just as smooth.
Note that now they are black not white. They look like the black 48p gear below but 78T in 64p. DB5078 $7.99ea.
This is the 78T gear with a 60T pinion on the DB12RR. Don't know if you would ever need a 110mm roll out but its nice to know you could get it if you needed to...lol!
AdrianM is offline
Old 01-02-2009, 06:55 PM
  #8242
Maybell's Avatar
Pretty Please!!!
Awesome Adrian! I will be shooting some business your way! Thanks!
Maybell is offline
Old 01-02-2009, 09:50 PM
  #8243
Rdog's Avatar
Trader Rating: 83 (100%+)
Has anyone tried running the itf chassis with the regular upper deck on carpet with rubber tires? If so was it good bad or same.
Rdog is offline
Old 01-02-2009, 11:04 PM
  #8244
mikel33's Avatar
Trader Rating: 2 (75%+)
I've done that. I think its still pretty good, but I am not necessarily the best judge of things. I do think it runs better with the ITF top deck. I was running someone else's for a while because we couldn't get any. The ITF seem to be a bit of a tweak monster if you hit the boards too often (as I do). To try and find a compromise, I cut off the crossmember at the rear on a standard topdeck. It seems to run pretty well that way. I run 17.5 stock rubber and my times are competitive with the modified top deck. I don't think its quite as good as the ITF but its not too bad.
mikel33 is offline
Old 01-02-2009, 11:11 PM
  #8245
Scottmisfits's Avatar
Hey guys, what's the smallest spur I can run to still get a good gear mesh with 13.5 and or 19t motors?
Scottmisfits is offline
Old 01-03-2009, 03:13 AM
  #8246
mr crum's Avatar
well i run 48 pitch and the smallest kimbrough i can get without hitting the top plate is a 72 t 48 pitch
mr crum is offline
Old 01-03-2009, 09:03 AM
  #8247
Sorry, I'm running 64p. Unless you can give me an exact O.D. of that spur.
Old 01-03-2009, 09:50 AM
  #8248
Trader Rating: 3 (80%+)
100 is about as small as you will want to go
Josh Hohnstein is offline
Old 01-03-2009, 10:47 AM
  #8249
sorry for asking again, but either i missed the answer or it was overlooked. what brand or rather part # 64 pitch spur you guys runnin? thanks
cleblanc is offline
Old 01-03-2009, 11:57 AM
  #8250
quietstorm76's Avatar
I agree. I'm running 100 now.
quietstorm76 is offline
