Team Associated TC5
#8386
IMO if you have ever had an Xray (any Xray) then this car (or really any other car) will not stand up to the fit, finish and quality of an Xray. Now having said that I also didn't pay $499 for my TC5. I really think that some of the tolerances are too big and that the quailty of material should be better i.e. axles, cvds and screws.
But I have to say that this is the best handling rubber/carpet car I have owned in a long time.
My $.02
#8387
My $.02
My $.02
#8388
Some VERY interesting mods seen on the team cars at this weekends DHI-Cup race in Europe. Most noticable is the upper camber link. Pictures at www.redrc.net click on events.
If I run out of things to change on my car tomorrow whilst testing may try some of these out.....
#8390
DIFFS?
So is there an easier way to build the diff. I can't get the diff spring bolt assembly to go in together right. I got the bolt jammed in as far as possible into the dogbone spring cup. but as soon as i put the whole assembly together, the screw doesn't reach.
I compressed the spring as much as i can with a vise already. I have built a good amount of kits with no problems but this kit is pretty tough. well at least the diff part is.
#8393
Pick up the part asc6575 that Robk posted. I had the same issue with my first build. My second build i decided to use thinner shims for the thrust bearing instead of the ones provided. I really dont know if that was a good idea yet but i'll find out very soon.
I was able to put one diff together the way associated intended. I put a small nut driver on the table put the diff on the nut driver and pressed down with the allen wrench. Basically i was a human press. For those that know me i'm a big boy so the extra weight helped.
#8397
Looks like TC5 had a decent outing at the Novak Race. I would be interested in Hohnstein and Herbert setups for 10.5 and 13.5 rubber. Could you let us know thanks..
#8399
Jim Piersol won 17.5 rubber with his TC5r.
I tq'd and finished second in 13.5 rubber........two very small driving errors cost me the win.
Nick Stampfel finished 5th in 13.5 rubber.
Bob Stellflue finished 3rd in 13.5 foam
Keven Hebert finished 2nd in 10.5 rubber and I finished 3rd in 10.5 rubber.
LeMieux was in a league of his own in that class.....
Keven also finished 2nd in mod foam.
As far as the rubber setups............I ran the setup I have posted here a few times........I did switch to a spool for sat and sun because I felt it was a little easier to race with.
Keven tried everything on his rubber car........I don't know exactly what he ended up with.
