Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 01-03-2009, 01:18 PM
  #8251
Scottmisfits's Avatar
To maintain the same gear ratio I'm at now, I need to be at 100/33 or something close to that. Thanks Josh.
I'm using the Robinso racing spur gears. Part number will change with the size.
Scottmisfits is offline
Old 01-03-2009, 01:54 PM
  #8252
Trader Rating: 3 (80%+)
I don't think you can get a 100/ 33 to work. The smallest pinion with a 100 spur is somewhere around a 35 or 36. Maybe go up to a 106?
Josh Hohnstein is offline
Old 01-03-2009, 05:33 PM
  #8253
Jim S's Avatar
Trader Rating: 30 (100%+)
whats a god starting point for on road carpet
i have a 112 spur
i have a lipo
i have a 13.5
looking for shock oil
spring
and sway bar if any
Jim S is offline
Old 01-03-2009, 06:01 PM
  #8254
carbon madness's Avatar
for foam tire, or rubber tire racing?
carbon madness is offline
Old 01-03-2009, 06:09 PM
  #8255
Jim S's Avatar
rubber
Jim S is offline
Old 01-03-2009, 06:38 PM
  #8256
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's http://www.rctech.net/forum/electric...ox-ratios.html
RielTime Racing is offline
Old 01-04-2009, 04:23 AM
  #8257
PartTime's Avatar
Originally Posted by cleblanc
sorry for asking again, but either i missed the answer or it was overlooked. what brand or rather part # 64 pitch spur you guys runnin? thanks
Look at the inside set of holes on any spur gear, if it has 6 holes you can run it in a tc5.
DK
PartTime is offline
Old 01-04-2009, 08:55 AM
  #8258
if your running in stock or 19t you don't need the three screws to hold the spur gear on. You only need two. Most 64p spur gears that we seem to be getting around here only have two holes that line up and I didn't have any issues with my TC5 and I haven't had any issues with my TC5R. Or with my '007, Pro 4.
Old 01-04-2009, 08:58 AM
  #8259
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
what 64 pitch spur works?
I run the Kimbrough gears because I can use three screws to secure the gear. I did try some others that only had two holes and I didn't have much luck with them, stripped them. Now that could just be my fault because I didn't set the gear mesh correctly so when I tapped the boards boom it was gone. Now when I tap the boards I have no worries.
Kraig is offline
Old 01-04-2009, 09:17 AM
  #8260
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
you dont TAP the boards.....
Matt M. is offline
Old 01-04-2009, 09:28 AM
  #8261
Super Moderator
Kraig's Avatar
As opposed to yours that sounds like a shotgun going off in an enclosed building they are.
Kraig is offline
Old 01-04-2009, 09:30 AM
  #8262
Administrator
Matt M.'s Avatar
go big or go home....
Matt M. is offline
Old 01-04-2009, 10:17 AM
  #8263
mr crum's Avatar
i agree they seem to strip out when u only use 2 screws the hub for the spur has 6 holes i use all 6 my spur gear doesnt move and more rotating mass helps carry corner speed
mr crum is offline
Old 01-04-2009, 11:11 AM
  #8264
I'dlove to know what I'm doing right if you guys are tapping boards and stripping spur gears. I watched a guy, who's car I pretty much built, rip a corner off of his car because of a head on impact with another car, right after he bounced off the boards and he's still using the same spur. I'm using the same spur I started the season with. 2 screws in it and all.
Old 01-04-2009, 02:04 PM
  #8265
Super Moderator
Kraig's Avatar
We just hit it really hard, that is all.
Kraig is offline
